Other than negative karma points for using a uuid device id (you should really use the entity id instead). I don’t see anything glaringly wrong… It’s a simple automation. but 2.74 seconds is a long time to turn off a switch. so I’m thinking there are likely additional automations getting triggered by those 3 switches turning on/off? is there?
I created this Automation using the GUI, So its not my doing of using UUID. I used the entity name (Maybe because the name was in other language than English?)
