Home Assistant 2022.9.5 Supervisor 2022.09.1 Operating System 9.0 Frontend 20220907.2 - latest
I’m using Hass o/s on a pi400 running from a 240gb SSD and using MariaDB instead of the default DB
Just recently the SSD is showing as full in HA and I cannot add integrations or update.
I suspected MariaDB so i created a sensor to get the size… which is only 290MB so it can’t be that.
I removed the SSD and stuck it in my widows laptop and it shows as full on there too (although there don’t seem to be many files, but maybe windows just cant see them)
@tmjpugh I’ve got Ubuntu on a usb on my laptop and plugged my Ssd in too, I can now see the contents of the SSD and a volume shows up … hassos-data which shows 229GB and full.
I have no idea what can and can’t be deleted though
Any help appreciated
I expect there are some .log file that is huge and may be deleted
Can you confirm your install method
Docker images can cause this but not sure how this works in supervised install. In any case find the large file that’s likely over a few GB and it’s the likely culprit
@tmjpugh yes mate, I’ve gone into every /var/lib I can find and can find no docker folder, never mind /overlay2
Strangely though if I plug the SSD into my laptop running Ubuntu, I can find it.
@tmjpugh I think I’m going to have to bite the bullet and re flash the SSD and install a backup and hope the backup doesn’t contain whatever is causing the problem.
Thanks for all your help
