Storage usage of my system
I run my Home Assistant instance in a VM and my storage is constantly running out down to 0.5GB and I have no idea why.
I have used ncdu / du in the terminal add-on and nothing adds up to the 60GB of storage I have allocated.
What would be nice to have is the storage section showing a breakdown of disk usage of my instance instead of just a percentage calculation
Maybe use command line sensor to create what you need.
HA logs may be eating your storage. Maybe change logging to reduce this.
