I use a Hetzner Storage Box to store my backups. Every night, during the forced disconnection, the connection is dropped and not re-established. I have to re-enter my username and password the next morning, and then it works again until 5 AM. This issue does not seem to occur if the internet connection is interrupted during the day. Has anyone else experienced this? I have the Storage Box mounted as Samba.
2024-12-13 06:26:42.083 INFO (MainThread) [supervisor.mounts.manager] Reloading mount: Storagebox
2024-12-13 06:26:52.279 ERROR (MainThread) [supervisor.mounts.mount] Reloading Storagebox did not succeed. Check host logs for errors from mount or systemd unit mnt-data-supervisor-mounts-Storagebox.mount for details.
2024-12-13 06:27:11.734 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 567, in _handle
return await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 199, in block_bad_requests
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 215, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 285, in token_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 298, in core_proxy
File "/usr/src/supervisor/supervisor/api/utils.py", line 64, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/src/supervisor/supervisor/api/backups.py", line 140, in list
data_backups = self._list_backups()
File "/usr/src/supervisor/supervisor/api/backups.py", line 124, in _list_backups
ATTR_SIZE: backup.size,
File "/usr/src/supervisor/supervisor/backups/backup.py", line 192, in size
if not self.tarfile.is_file():
File "/usr/local/lib/python3.12/pathlib.py", line 892, in is_file
return S_ISREG(self.stat().st_mode)
File "/usr/local/lib/python3.12/pathlib.py", line 840, in stat
return os.stat(self, follow_symlinks=follow_symlinks)
OSError: [Errno 112] Host is down: '/data/mounts/Storagebox/15c475ed.tar'
2024-12-13 06:30:02.486 ERROR (MainThread) [aiohttp.server] Error handling request
2024-12-13 06:30:49.414 INFO (MainThread) [supervisor.mounts.manager] Removing mount: Storagebox
