Hi, I’m trying to migrate to a new deployment workflow but running into problems because the config folder contains both configuration and persistent data.
I’m running HA with Docker on a local Kubernetes instance.
At startup the config is pulled from Git and stored in a temporary config folder, so all information in this folder is refreshed during restarts. I’ve found I can relocate the database file to a different location so I can mount a hostpath to keep that information between restarts.
But the problem is with other persistent data, especially the following files/folders:
.storage/
.homekit.state
.ios.conf
.uuid
Is there a way to write those files to a different location?
Bind mounts won’t work in this situation. At startup I would like to replace the complete config in the directory with the config from Git. This ensures the Git config is correct and there are no local changes.
