Hi, This automation triggers each time the shelly switch is pressed, via mqtt
The problem is, it also polls every 30 seconds so it triggers each 30 seconds as well
alias: shelly_test
description: ""
- platform: mqtt
topic: shellies/shelly1l-E8DB84AB4E5D/input/0
condition:
- condition: template
value_template: "{{trigger.payload != input_number.current_shelly_switch_input}}"
- type: toggle
device_id: b8ec72d8f44c0beca6bcfda68dbd0c57
entity_id: light.luz_armario
domain: light
- service: input_number.set_value
value: "{{trigger.payload}}"
entity_id: input_number.current_shelly_switch_input
mode: single
I’m not sure if the condition works, and I’m not sure if I’m saving the payload value correctly in the input_number helper I created.
The payload it self is either a 0 or a 1
