'StoreManager.add_repository' blocked from execution, no supervisor internet connection
Hello
I have a supported supervised installation running on a RPI3+. It installed perfectly and i have been using the system for a few days now. All of a sudden i am unable to add any repositories and also check for any updates. It seems all all relates to the same issue of the supervisor not being able to reach the internet.
from within the docker container itself i am able to ping and resolve names so unsure of what else to check
fa0a078a2253:~# ping google.com
PING google.com (142.250.200.46): 56 data bytes
64 bytes from 142.250.200.46: seq=0 ttl=118 time=11.276 ms
64 bytes from 142.250.200.46: seq=1 ttl=118 time=12.761 ms
64 bytes from 142.250.200.46: seq=2 ttl=118 time=10.822 ms
Does anyone have any further suggestions to troubleshoot please?
Thank you
Hi, did you find a solution to the problem that I had the same problem?
Welcome to the community.
nope, I tried all sorts, within the container, debugging tools etc. Still couldnt work it out. I therefore just went with HASS OS. It works alot more slicker than the supervised version (with some caveats). Performance of the pages is alot more acceptable as well. :slight_smile:
