Is it possible to trigger storing a KNX-scene from Home Assistant? On KNX this is done by setting bit 7 of the scene number; does this also work for Home Assistant?
Side question: I see that the scenes function is for sending only, and the sensor does not support the scene DPT, so I need to use the “Fire Event” function for this?
Thanks,
Thomas
