Stove working time showed in a card
Hello everyone, I am looking to track my pellet consumption for my stove and I would like to be able to display the cumulative heating time over a 24-hour period in a card.
The entity in question is called
sensor.nobis_status
with Raw Values ​​varying from 1 to 8 knowing that 3 corresponds to WORK.
Can you help me get the result I’m looking for? thanks in advance
Hi @Daarz,
you can create a template sensor, that calculates, if your stove is on or off.
Go to Settings → Devices → Helpers → create a new template sensor.
You could use something like this:
{% if states('sensor.nobis_status') | float = 3}
          on
        {% else %}
          off
        {% endif %}
Go to Developer Tools → Template to test the code, before you create your template sensor.
Chris
That template can be simplified to:
{{ is_state('sensor.nobis_status', '3')  }}
However it is not needed you can use the history stats integration with your sensor directly
  - platform: history_stats
    name: Stove on today
    entity_id: sensor.nobis_status
    state: "3"
    type: time
    start: "{{ now().replace(hour=0, minute=0, second=0) }}"
    end: "{{ now() }}"
