Good morning,
I have done the adb connection and installed logcat. The access to device log seems ok.
Then, I do the home assistant connection attemps again and saved the log covering this time period.
I attach the log txt file
With a global search, I do not see anything showing “homeassistant”… weird.
All I see is a warning “inputeventreceiver” saying “Attepmt to finish an input event but the input event receiver has already been disposed.”
Do you see anthing that strikes you?
I can’t figure out why it work everywhere fine except on this tablet, on which it used to work fine. I event tried to re-install HA_app clean…
<<< log_count = 287 >>>
[11-25 08:10:16.087 12529:12529 D/InputTransport]
Input channel destroyed: fd=82
[11-25 08:10:22.389 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
ViewPostImeInputStage processPointer 0
[11-25 08:10:22.462 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
ViewPostImeInputStage processPointer 1
[11-25 08:10:22.477 12529:12529 D/TextView]
setTypeface with style : 0
[11-25 08:10:22.488 12529:12529 D/TextView]
[11-25 08:10:22.492 12529:12529 D/TextView]
[11-25 08:10:22.499 12529:12529 D/TextView]
[11-25 08:10:22.500 12529:12529 D/TextView]
[11-25 08:10:22.502 12529:12529 D/TextView]
[11-25 08:10:24.522 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
MSG_WINDOW_FOCUS_CHANGED 0
[11-25 08:10:24.527 12529:12529 D/LogcatReader]
[Logcat] onActivityInBackground
[11-25 08:10:24.593 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
mHardwareRenderer.destroy()#1
[11-25 08:10:24.598 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
Relayout returned: oldFrame=[0,0][2048,1536] newFrame=[0,0][2048,1536] result=0x5 surface={isValid=false 0} surfaceGenerationChanged=true
[11-25 08:10:24.622 12529:12529 D/InputTransport]
Input channel destroyed: fd=80
[11-25 08:10:24.675 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:24.680 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
Relayout returned: oldFrame=[0,0][2048,1536] newFrame=[0,0][2048,1536] result=0x1 surface={isValid=false 0} surfaceGenerationChanged=false
[11-25 08:10:51.765 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:51.769 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:51.776 12529:12529 D/LogcatReader]
[Logcat] onActivityInForeground
[Logcat] Posting pending logs
[11-25 08:10:51.789 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
Relayout returned: oldFrame=[0,0][2048,1536] newFrame=[0,0][2048,1536] result=0x3 surface={isValid=true -1932759040} surfaceGenerationChanged=true
mHardwareRenderer.initialize() mSurface={isValid=true -1932759040} hwInitialized=true
[11-25 08:10:51.793 12529:12554 D/mali_winsys]
EGLint new_window_surface(egl_winsys_display*, void*, EGLSurface, EGLConfig, egl_winsys_surface**, egl_color_buffer_format*, EGLBoolean) returns 0x3000, [2048x1536]-format:1
[11-25 08:10:51.795 12529:12529 D/LogcatReader]
[LogcatLiveFragment] onServiceConnected
[11-25 08:10:51.797 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
MSG_WINDOW_FOCUS_CHANGED 1
[11-25 08:10:51.798 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
mHardwareRenderer.initializeIfNeeded()#2 mSurface={isValid=true -1932759040}
[11-25 08:10:51.799 12529:12529 V/InputMethodManager]
Starting input: tba=android.view.inputmethod.EditorInfo@75776c4 nm : com.dp.logcatapp ic=null
[11-25 08:10:51.799 12529:12529 I/InputMethodManager]
[IMM] startInputInner - mService.startInputOrWindowGainedFocus
[11-25 08:10:51.805 12529:12529 D/InputTransport]
Input channel constructed: fd=65
[11-25 08:10:51.923 12529:12529 D/TextView]
[11-25 08:10:51.924 12529:12529 D/TextView]
[11-25 08:10:51.925 12529:12529 D/TextView]
[11-25 08:10:51.926 12529:12529 D/TextView]
[11-25 08:10:51.927 12529:12529 D/TextView]
[11-25 08:10:51.930 12529:12529 D/TextView]
[11-25 08:10:51.931 12529:12529 D/TextView]
[11-25 08:10:51.932 12529:12529 D/TextView]
[11-25 08:10:51.933 12529:12529 D/TextView]
[11-25 08:10:51.934 12529:12529 D/TextView]
[11-25 08:10:51.938 12529:12529 D/TextView]
[11-25 08:10:51.939 12529:12529 D/TextView]
[11-25 08:10:51.940 12529:12529 D/TextView]
[11-25 08:10:51.941 12529:12529 D/TextView]
[11-25 08:10:51.945 12529:12529 D/TextView]
[11-25 08:10:51.946 12529:12529 D/TextView]
[11-25 08:10:51.947 12529:12529 D/TextView]
[11-25 08:10:51.948 12529:12529 D/TextView]
[11-25 08:10:51.952 12529:12529 D/TextView]
[11-25 08:10:51.953 12529:12529 D/TextView]
[11-25 08:10:51.954 12529:12529 D/TextView]
[11-25 08:10:51.955 12529:12529 D/TextView]
[11-25 08:10:51.958 12529:12529 D/TextView]
[11-25 08:10:51.959 12529:12529 D/TextView]
[11-25 08:10:51.960 12529:12529 D/TextView]
[11-25 08:10:51.961 12529:12529 D/TextView]
[11-25 08:10:51.965 12529:12529 D/TextView]
[11-25 08:10:51.966 12529:12529 D/TextView]
[11-25 08:10:51.967 12529:12529 D/TextView]
[11-25 08:10:51.968 12529:12529 D/TextView]
[11-25 08:10:51.969 12529:12529 D/TextView]
[11-25 08:10:51.972 12529:12529 D/TextView]
[11-25 08:10:51.973 12529:12529 D/TextView]
[11-25 08:10:51.974 12529:12529 D/TextView]
[11-25 08:10:51.975 12529:12529 D/TextView]
[11-25 08:10:52.628 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:52.736 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:54.139 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:54.227 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:55.296 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:55.392 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:55.413 12529:12529 D/TextView]
[11-25 08:10:55.415 12529:12529 D/TextView]
[11-25 08:10:55.416 12529:12529 D/TextView]
[11-25 08:10:55.417 12529:12529 D/TextView]
[11-25 08:10:55.418 12529:12529 D/TextView]
[11-25 08:10:55.419 12529:12529 D/TextView]
[11-25 08:10:55.420 12529:12529 D/TextView]
[11-25 08:10:55.425 12529:12529 D/TextView]
[11-25 08:10:55.426 12529:12529 D/TextView]
[11-25 08:10:55.428 12529:12529 D/TextView]
[11-25 08:10:55.429 12529:12529 D/TextView]
[11-25 08:10:55.430 12529:12529 D/TextView]
[11-25 08:10:55.431 12529:12529 D/TextView]
[11-25 08:10:55.432 12529:12529 D/TextView]
[11-25 08:10:55.437 12529:12529 D/TextView]
[11-25 08:10:55.438 12529:12529 D/TextView]
[11-25 08:10:55.439 12529:12529 D/TextView]
[11-25 08:10:55.440 12529:12529 D/TextView]
[11-25 08:10:55.442 12529:12529 D/TextView]
[11-25 08:10:55.443 12529:12529 D/TextView]
[11-25 08:10:55.444 12529:12529 D/TextView]
[11-25 08:10:55.449 12529:12529 D/TextView]
[11-25 08:10:55.450 12529:12529 D/TextView]
[11-25 08:10:55.451 12529:12529 D/TextView]
[11-25 08:10:55.453 12529:12529 D/TextView]
[11-25 08:10:55.454 12529:12529 D/TextView]
[11-25 08:10:55.455 12529:12529 D/TextView]
[11-25 08:10:55.460 12529:12529 D/TextView]
[11-25 08:10:55.462 12529:12529 D/TextView]
[11-25 08:10:55.463 12529:12529 D/TextView]
[11-25 08:10:55.464 12529:12529 D/TextView]
[11-25 08:10:55.465 12529:12529 D/TextView]
[11-25 08:10:55.466 12529:12529 D/TextView]
[11-25 08:10:55.467 12529:12529 D/TextView]
[11-25 08:10:55.472 12529:12529 D/TextView]
[11-25 08:10:55.473 12529:12529 D/TextView]
[11-25 08:10:55.474 12529:12529 D/TextView]
[11-25 08:10:55.475 12529:12529 D/TextView]
[11-25 08:10:55.476 12529:12529 D/TextView]
[11-25 08:10:55.477 12529:12529 D/TextView]
[11-25 08:10:55.478 12529:12529 D/TextView]
[11-25 08:10:55.483 12529:12529 D/TextView]
[11-25 08:10:55.485 12529:12529 D/TextView]
[11-25 08:10:55.486 12529:12529 D/TextView]
[11-25 08:10:55.487 12529:12529 D/TextView]
[11-25 08:10:55.488 12529:12529 D/TextView]
[11-25 08:10:55.489 12529:12529 D/TextView]
[11-25 08:10:55.494 12529:12529 D/TextView]
[11-25 08:10:55.495 12529:12529 D/TextView]
[11-25 08:10:55.496 12529:12529 D/TextView]
[11-25 08:10:55.497 12529:12529 D/TextView]
[11-25 08:10:55.498 12529:12529 D/TextView]
[11-25 08:10:55.499 12529:12529 D/TextView]
[11-25 08:10:55.500 12529:12529 D/TextView]
[11-25 08:10:55.505 12529:12529 D/TextView]
[11-25 08:10:55.506 12529:12529 D/TextView]
[11-25 08:10:55.507 12529:12529 D/TextView]
[11-25 08:10:55.508 12529:12529 D/TextView]
[11-25 08:10:55.509 12529:12529 D/TextView]
[11-25 08:10:55.510 12529:12529 D/TextView]
[11-25 08:10:55.514 12529:12529 D/TextView]
[11-25 08:10:55.515 12529:12529 D/TextView]
[11-25 08:10:55.516 12529:12529 D/TextView]
[11-25 08:10:55.517 12529:12529 D/TextView]
[11-25 08:10:55.518 12529:12529 D/TextView]
[11-25 08:10:55.519 12529:12529 D/TextView]
[11-25 08:10:55.523 12529:12529 D/TextView]
[11-25 08:10:55.524 12529:12529 D/TextView]
[11-25 08:10:55.525 12529:12529 D/TextView]
[11-25 08:10:55.526 12529:12529 D/TextView]
[11-25 08:10:55.527 12529:12529 D/TextView]
[11-25 08:10:55.528 12529:12529 D/TextView]
[11-25 08:10:55.532 12529:12529 D/TextView]
[11-25 08:10:55.533 12529:12529 D/TextView]
[11-25 08:10:55.534 12529:12529 D/TextView]
[11-25 08:10:55.535 12529:12529 D/TextView]
[11-25 08:10:55.536 12529:12529 D/TextView]
[11-25 08:10:55.537 12529:12529 D/TextView]
[11-25 08:10:56.352 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:56.481 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:57.510 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:10:57.665 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:00.059 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:00.179 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:01.033 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:01.098 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:02.092 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:02.234 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:04.091 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:04.219 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:15.976 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:16.128 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:16.445 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:16.675 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:17.378 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:17.456 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:18.442 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:18.518 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:19.503 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:19.600 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:20.787 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:20.905 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:21.081 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:21.157 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:21.167 12529:12529 D/AbsListView]
Get MotionRecognitionManager
[11-25 08:11:21.175 12529:12529 D/TextView]
[11-25 08:11:21.177 12529:12529 D/TextView]
[11-25 08:11:21.181 12529:12529 D/TextView]
[11-25 08:11:21.182 12529:12529 D/TextView]
[11-25 08:11:21.184 12529:12529 D/TextView]
[11-25 08:11:21.187 12529:12529 D/ViewRootImpl@83bf80b[MainActivity]]
ThreadedRenderer.create() translucent=true
[11-25 08:11:21.190 12529:12529 D/InputTransport]
Input channel constructed: fd=69
[11-25 08:11:21.190 12529:12529 D/ViewRootImpl@83bf80b[MainActivity]]
setView = DecorView@a9e26e8[MainActivity] touchMode=true
[11-25 08:11:21.192 12529:12529 D/ViewRootImpl@83bf80b[MainActivity]]
dispatchAttachedToWindow
[11-25 08:11:21.194 12529:12529 D/TextView]
[11-25 08:11:21.214 12529:12529 D/ViewRootImpl@83bf80b[MainActivity]]
Relayout returned: oldFrame=[0,0][0,0] newFrame=[512,457][1536,1121] result=0x27 surface={isValid=true -1931501568} surfaceGenerationChanged=true
[11-25 08:11:21.215 12529:12529 D/ViewRootImpl@83bf80b[MainActivity]]
mHardwareRenderer.initialize() mSurface={isValid=true -1931501568} hwInitialized=true
[11-25 08:11:21.216 12529:12554 D/mali_winsys]
EGLint new_window_surface(egl_winsys_display*, void*, EGLSurface, EGLConfig, egl_winsys_surface**, egl_color_buffer_format*, EGLBoolean) returns 0x3000, [1136x776]-format:1
[11-25 08:11:21.219 12529:12529 D/TextView]
[11-25 08:11:21.220 12529:12529 D/TextView]
[11-25 08:11:21.222 12529:12529 D/TextView]
[11-25 08:11:21.223 12529:12529 D/TextView]
[11-25 08:11:21.224 12529:12529 D/TextView]
[11-25 08:11:21.225 12529:12529 D/AbsListView]
onsize change
[11-25 08:11:21.233 12529:12529 D/ViewRootImpl@83bf80b[MainActivity]]
mHardwareRenderer.initializeIfNeeded()#2 mSurface={isValid=true -1931501568}
[11-25 08:11:21.236 12529:12529 D/TextView]
[11-25 08:11:21.253 12529:12529 D/ViewRootImpl@83bf80b[MainActivity]]
MSG_RESIZED_REPORT: frame=Rect(512, 457 - 1536, 1121) ci=Rect(0, 0 - 0, 0) vi=Rect(0, 0 - 0, 0) or=2
[11-25 08:11:21.277 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:21.278 12529:12529 D/ViewRootImpl@83bf80b[MainActivity]]
[11-25 08:11:21.290 12529:12529 D/ViewRootImpl@83bf80b[MainActivity]]
mHardwareRenderer.destroy()#4
dispatchDetachedFromWindow
[11-25 08:11:21.312 12529:12529 W/InputEventReceiver]
Attempted to finish an input event but the input event receiver has already been disposed.
[11-25 08:11:21.312 12529:12529 W/ViewRootImpl@83bf80b[MainActivity]]
Dropping event due to root view being removed:
[11-25 08:11:21.312 12529:12529 E/ViewRootImpl@83bf80b[MainActivity]]
mStopped=false mHasWindowFocus=true mPausedForTransition=false
[11-25 08:11:21.312 12529:12529 D/InputTransport]
Input channel destroyed: fd=69
[11-25 08:11:21.313 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:21.315 12529:12529 E/ViewRootImpl]
sendUserActionEvent() returned.
[11-25 08:11:22.436 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:22.542 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:25.777 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:25.852 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:27.812 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:27.885 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:28.836 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:28.920 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:29.884 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:29.980 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:30.090 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:30.166 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:30.183 12529:12529 D/AbsListView]
[11-25 08:11:30.192 12529:12529 D/TextView]
[11-25 08:11:30.195 12529:12529 D/TextView]
[11-25 08:11:30.198 12529:12529 D/TextView]
[11-25 08:11:30.199 12529:12529 D/TextView]
[11-25 08:11:30.200 12529:12529 D/TextView]
[11-25 08:11:30.204 12529:12529 D/ViewRootImpl@3f575a7[MainActivity]]
[11-25 08:11:30.207 12529:12529 D/InputTransport]
Input channel constructed: fd=80
[11-25 08:11:30.207 12529:12529 D/ViewRootImpl@3f575a7[MainActivity]]
setView = DecorView@f862a54[MainActivity] touchMode=true
[11-25 08:11:30.209 12529:12529 D/ViewRootImpl@3f575a7[MainActivity]]
[11-25 08:11:30.211 12529:12529 D/TextView]
[11-25 08:11:30.226 12529:12529 D/ViewRootImpl@3f575a7[MainActivity]]
Relayout returned: oldFrame=[0,0][0,0] newFrame=[512,457][1536,1121] result=0x27 surface={isValid=true -1932582912} surfaceGenerationChanged=true
mHardwareRenderer.initialize() mSurface={isValid=true -1932582912} hwInitialized=true
[11-25 08:11:30.230 12529:12529 D/TextView]
[11-25 08:11:30.231 12529:12554 D/mali_winsys]
[11-25 08:11:30.232 12529:12529 D/TextView]
[11-25 08:11:30.233 12529:12529 D/TextView]
[11-25 08:11:30.234 12529:12529 D/TextView]
[11-25 08:11:30.236 12529:12529 D/TextView]
[11-25 08:11:30.236 12529:12529 D/AbsListView]
onsize change
[11-25 08:11:30.248 12529:12529 D/ViewRootImpl@3f575a7[MainActivity]]
mHardwareRenderer.initializeIfNeeded()#2 mSurface={isValid=true -1932582912}
[11-25 08:11:30.251 12529:12529 D/TextView]
[11-25 08:11:30.269 12529:12529 D/ViewRootImpl@3f575a7[MainActivity]]
[11-25 08:11:30.285 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:31.184 12529:12529 D/ViewRootImpl@3f575a7[MainActivity]]
[11-25 08:11:31.192 12529:12529 D/ViewRootImpl@3f575a7[MainActivity]]
[11-25 08:11:31.205 12529:12529 W/InputEventReceiver]
[11-25 08:11:31.205 12529:12529 W/ViewRootImpl@3f575a7[MainActivity]]
[11-25 08:11:31.205 12529:12529 E/ViewRootImpl@3f575a7[MainActivity]]
[11-25 08:11:31.205 12529:12529 D/InputTransport]
[11-25 08:11:31.206 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:31.208 12529:12529 E/ViewRootImpl]
[11-25 08:11:31.913 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
[11-25 08:11:32.053 12529:12529 D/ViewRootImpl@f2d1c01[MainActivity]]
