Strange Behavior with Hue Lamps
I have Hue bulb in yard post lamp that works 95% of the time but will go through periods when I can control it via the Hue app but not with HA. This morning for example it was still on and HA could not contact it, however, I was able to turn it off via the Hue app. I have HA connected to a Hue bridge to control Hue bulbs so I would expect that if the app can contact the bulb, HA should.as well.
Could it be a polling issue?
Also, occasionally this bulb and others will turn on at the desired time but not at desired brightness. I don’t know how that could happen either.
All help appreciated, thanks,
Paul
Logs? where did put them?
Not sure how to include logs but I’ll figure it out.
