Since migrating to 0.115 I am having problems with Kodi controls. Integrations has successfully detected my Kodi device but HASS is doing some very weird things.
If I restart HASS I get the following error in the log…
Log Details (ERROR)
Logger: homeassistant.components.kodi.config_flow
Source: components/kodi/config_flow.py:51
Integration: Kodi (documentation, issues)
First occurred: 18:16:31 (1 occurrences)
Last logged: 18:16:31Cannot connect to Kodi
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 936, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore # noqa
File “/usr/local/lib/python3.8/asyncio/base_events.py”, line 1025, in create_connection
raise exceptions[0]
File “/usr/local/lib/python3.8/asyncio/base_events.py”, line 1010, in create_connection
sock = await self._connect_sock(
File “/usr/local/lib/python3.8/asyncio/base_events.py”, line 924, in _connect_sock
await self.sock_connect(sock, address)
File “/usr/local/lib/python3.8/asyncio/selector_events.py”, line 494, in sock_connect
return await fut
File “/usr/local/lib/python3.8/asyncio/selector_events.py”, line 526, in _sock_connect_cb
raise OSError(err, f’Connect call failed {address}')
ConnectionRefusedError: [Errno 111] Connect call failed (‘192.168.1.115’, 8080)The above exception was the direct cause of the following exception:
File “/usr/local/lib/python3.8/site-packages/jsonrpc_async/jsonrpc.py”, line 32, in send_message
response = await self._request(data=message.serialize())
File “/usr/local/lib/python3.8/site-packages/aiohttp/client.py”, line 480, in _request
conn = await self._connector.connect(
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 523, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 858, in _create_connection
_, proto = await self._create_direct_connection(
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 1004, in _create_direct_connection
raise last_exc
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 980, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 943, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 192.168.1.115:8080 ssl:default [Connect call failed (‘192.168.1.115’, 8080)]During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.8/site-packages/pykodi/kodi.py”, line 161, in ping
response = await self._server.JSONRPC.Ping()
File “/usr/local/lib/python3.8/site-packages/jsonrpc_async/jsonrpc.py”, line 34, in send_message
raise TransportError(‘Transport Error’, message, exc)
jsonrpc_base.jsonrpc.TransportError: (“Error calling method ‘JSONRPC.Ping’: Transport Error”, ClientConnectorError(ConnectionKey(host=‘192.168.1.115’, port=8080, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=269936207), ConnectionRefusedError(111, “Connect call failed (‘192.168.1.115’, 8080)”)))The above exception was the direct cause of the following exception:
File “/usr/src/homeassistant/homeassistant/components/kodi/config_flow.py”, line 49, in validate_http
await kodi.ping()
File “/usr/local/lib/python3.8/site-packages/pykodi/kodi.py”, line 167, in ping
raise CannotConnectError from error
pykodi.kodi.CannotConnectErrorThe above exception was the direct cause of the following exception:
File “/usr/src/homeassistant/homeassistant/components/kodi/config_flow.py”, line 220, in async_step_import
await validate_http(self.hass, data)
File “/usr/src/homeassistant/homeassistant/components/kodi/config_flow.py”, line 51, in validate_http
raise CannotConnect from error
homeassistant.components.kodi.config_flow.CannotConnect
Home Assistant has started!
OK so the port on Kodi @ 192.168.1.115 is actually 9090 I can prove this because I can connect to Kodi OK using browser to http://192.168.1.115:9090;
Lets change it (on kodi) to 8080 (I can now connect to kodi OK using browser to http://192.168.1.115:8080)
Do nothing to HASS except restart.
I now get the following error in the log (having never touched HASS Settings at all):
Source: components/kodi/config_flow.py:82
First occurred: 18:24:01 (1 occurrences)
Last logged: 18:24:01Unexpected exception
raise exceptions[0]
return await fut
ConnectionRefusedError: [Errno 111] Connect call failed (‘192.168.1.115’, 9090)The above exception was the direct cause of the following exception:
File “/usr/local/lib/python3.8/site-packages/jsonrpc_websocket/jsonrpc.py”, line 56, in ws_connect
self._client = await self.session.ws_connect(
File “/usr/local/lib/python3.8/site-packages/aiohttp/client.py”, line 721, in _ws_connect
resp = await self.request(method, url,
raise last_exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 192.168.1.115:9090 ssl:default [Connect call failed (‘192.168.1.115’, 9090)]During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.8/site-packages/pykodi/kodi.py”, line 135, in connect
await self._ws_server.ws_connect()
File “/usr/local/lib/python3.8/site-packages/jsonrpc_websocket/jsonrpc.py”, line 59, in ws_connect
raise TransportError(‘Error connecting to server’, None, exc)
jsonrpc_base.jsonrpc.TransportError: (‘Error connecting to server’, ClientConnectorError(ConnectionKey(host=‘192.168.1.115’, port=9090, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=1902911753), ConnectionRefusedError(111, “Connect call failed (‘192.168.1.115’, 9090)”)))The above exception was the direct cause of the following exception:
File “/usr/src/homeassistant/homeassistant/components/kodi/config_flow.py”, line 75, in validate_ws
await kwc.connect()
File “/usr/local/lib/python3.8/site-packages/pykodi/kodi.py”, line 137, in connect
File “/usr/src/homeassistant/homeassistant/components/kodi/config_flow.py”, line 221, in async_step_import
await validate_ws(self.hass, data)
File “/usr/src/homeassistant/homeassistant/components/kodi/config_flow.py”, line 82, in validate_ws
raise WSCannotConnect from error
homeassistant.components.kodi.config_flow.WSCannotConnect
Any help on this gratefully received!
