Strange behaviour with the wake_on_lan Switch
I have been using the Wake on LAN feature for some time now, it works great. I had one PC that did not work; but it wasn’t working with anything so not the fault of Home Assistant.
It turned out, it was the NIC.
After replacing the NIC, I can wake up the system from the CLI of my Mac like so:
wakeonlan -i 192.168.1.255 -p 1234 12:34:56:78:90:AB
And, the system wakes up and boots as you would expect.
When I edited my switch.yaml to update the MAC address there the switch does not work - it gets greyed out:
And when you try to click on the switch it shows:
You will notice that there are two greyed out switches there. The VR PC which is “real” and the “wake_me_up” which is just a placeholder test.
I added wake_on_lan: to my config.yaml (I never needed it before) And the yaml in my switches.yaml is:
I have tried adding quotes, changing MAC delimiters etc, but not effect. I am not sure why wake on lan is doing this now - it never did before. (Maybe the wake on lan MQTT I have for PS5 is impacting it?)
I am kind of at a loss.
The first switch in the image - wake_game_pc works just fine, exactly as expected. However, as soon as I updated the MAC address on wake_vr_pc it got greyed out. That’s why I picked the test switch below that.
So… what is going on here? What am I missing? As mentioned, I can wake the system just fine with an actual magic packet - I just can’t get HA to see this as a switch anymore for reasons I cannot discern.
And to add to the strangeness, I created a “new” switch, that I named wake_gorilla_pc with the new MAC address, and I CAN wake the VR PC using this new switch.
Though, the icon does not display correctly in the GUI. I am at a loss as to why this worked.
Looks like some relation to the entity names…
Well, after renaming and deleting the switches, it works now. The icon is wrong, but it works:
