Hi there,
I do have a strange problem. When I open the home assistant UI on my mac with Chrome or Opera One, I geht strange Characters and I don’t know how to fix it.
It’s not only on the login - it’s on the whole UI.
I’m assuming you’re not attempting to summon the Great Old Ones?
Does it only happen on the Mac? Can you test from another system?
Unfortunately I just have my iphone and ipad here - both are working fine on the UI of home assistant. Even with the installed chrome browser on my iphone it worked.
It has to be a local problem on my mac - but I don’t know where to find it.
Just for your information - I don’t have any extra proxies installed in my network. No popup blocker - webfilter ect. nothing …
noone any idea?
Maybe this?
I have the same problem on mac. If I use safari it’s ok, with other browsers characters are weird.
Any solution?
The first row of text is the same of yours! If I copy text and paste anywhere I get the right english words!
I found it, I had the ROBOTO font installed on my Mac which was causing problems.
I removed it and that solved all my problems.
Similar issue here on Mac Chrome and Safari. In the state_content of tile cards, items are separated by an unreadable character “⸱” which should be a dot, but is instead just a square in the browser. According to Bash, this is not a legit ascii character.
printf '%d\n' "'⸱"
-30
Is there any way we can change the separator character or manually build that status line?
