Hi All,
For long time all my lights working perfect. But at a certain moment i see those errors pop up in the error log.
I dont know how to solve this. Tried many things. Maybe HA has changes some things i dont know.
(it is 1 line but its always more then 1. But show one)
2021-08-10 06:23:54 ERROR (MainThread) [homeassistant.util.logging] Exception in state_received when handling msg on 'Milight_Hub/states/0xAAAB/rgb_cct/1': '{"status":"ON","brightness":"255"}'
File "/usr/src/homeassistant/homeassistant/components/mqtt/debug_info.py", line 34, in wrapper
msg_callback(msg)
File "/usr/src/homeassistant/homeassistant/components/mqtt/light/schema_json.py", line 299, in state_received
if values["state"] == "ON":
KeyError: 'state'
- name: "Bedroom 5"
command_topic: "Milight_Hub/0xAAAB/rgb_cct/1"
state_topic: "Milight_Hub/states/0xAAAB/rgb_cct/1"
platform: mqtt
schema: json
color_temp: true
rgb: true
brightness: true
effect: true
qos: 1
optimistic: true
retain: false
availability_topic: "Milight_Hub/client_status"
payload_available: "connected"
payload_not_available: "disconnected"
effect_list:
- "night_mode"
- "white_mode"
- "0"
- "1"
- "2"
- "3"
- "4"
- "5"
- "6"
- "7"
- "8"
