I can’t figure out to what this relate inside Home assistant, it shows in log after restart each time only once.
/config # cat home-assistant.log
2020-07-15 12:25:54 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/ssdp/__init__.py", line 38, in initialize
await scanner.async_scan(None)
File "/usr/src/homeassistant/homeassistant/components/ssdp/__init__.py", line 61, in async_scan
await self._process_entries(entries)
File "/usr/src/homeassistant/homeassistant/components/ssdp/__init__.py", line 85, in _process_entries
result for result in await asyncio.gather(*tasks) if result is not None
File "/usr/src/homeassistant/homeassistant/components/ssdp/__init__.py", line 120, in _process_entry
info.update(await info_req)
File "/usr/src/homeassistant/homeassistant/components/ssdp/__init__.py", line 138, in _fetch_description
xml = await resp.text()
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 1014, in text
return self._body.decode(encoding, errors=errors) # type: ignore
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xc0 in position 229: invalid start byte
I’m running HA in docker on unraid, it doesn’t seems to affect anything but would be nice to find out why is it complaining.
