WARNING (SyncWorker_4) [supervisor.store.data] Can’t read /data/addons/git/db21ed7f/netalertx/config.json: expected str for dictionary value @ data[‘environment’][‘APP_CONF_OVERRIDE’]. Got {‘GRAPHQL_PORT’: ‘20212’}
I just noticed this error in “System info” but i have no idea whats causing it. I dont think i have any “netalertx” integration installed. Does anyone have any clue about what might be causing this?
Ok then it is a misconfiguration of that add-on’s store settings. You have the repository so you see the store misconfiguration warnings for it. If you don’t use any of the add-ons from the custom repository you could just remove the repository.
Actually I can’t find a repository for a NetAlertX add-on anywhere.
EDIT: Have you tried to add a docker container outside the add-on store system?
Thank you Tom. Exactly, that was my thinking. I already removed the repositories not in use to see if this would clear out but it didnt worked. And im not sure when this error starting showing as i dont check this System Info tab that often tbh.
