Strange error in the script
I’m trying to set my thermostat in automatic mode, but HA gives me an error that I can’t understand:
Stopped because an error was encountered, must contain at least one of temperature, target_temp_high, target_temp_low
This is my script:
caldaia_auto:
  sequence:
  - service: climate.set_temperature
      hvac_mode: 'auto'
      entity_id:
        - climate.termostato
and this is my thermostat:
hvac_modes:
  - auto
  - heat
  - 'off'
min_temp: 7
max_temp: 30
target_temp_step: 0.5
preset_modes:
  - away
  - boost
  - Frost Guard
  - Schedule
current_temperature: 19.4
temperature: 18
hvac_action: idle
preset_mode: Schedule
attribution: Data provided by Netatmo
selected_schedule: Base
friendly_name: Termostato
supported_features: 17
I also tried to change the structure by “mixing” the lines
caldaia_auto:
  sequence:
    entity_id: climate.termostato
      hvac_mode: 'auto'
but without success: the error is always the same.
Can you help me? Thank you
caldaia_auto:
  sequence:
      hvac_mode: 'auto'
Nothing to do, HA report the same error .
Solved. This is enough:
service: climate.set_hvac_mode
instead of
service: climate.set_temperature.
@tom_l , thanks anyway .
