Strange error "Missing slot list {licht}" after setting up automations with the senctence trigger
I had already set up some working automations using the Sentence trigger some time ago and have been able to even use them from my Garmin Venu 2 via HTTP WiFi requests.
Today, when I wanted to use one of those commands again, I noticed that it didn’t work.
I opened the Home Assistant logs and saw this:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:226
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 10:52:41 (5 occurrences)
Last logged: 14:43:49
[546823912256] Missing slot list {licht}
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 226, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2012, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2049, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/components/conversation/__init__.py", line 164, in handle_process
    result = await async_converse(
  File "/usr/src/homeassistant/homeassistant/components/conversation/__init__.py", line 467, in async_converse
    result = await agent.async_process(
  File "/usr/src/homeassistant/homeassistant/components/conversation/default_agent.py", line 202, in async_process
    if trigger_result := await self._match_triggers(user_input.text):
  File "/usr/src/homeassistant/homeassistant/components/conversation/default_agent.py", line 702, in _match_triggers
    for result in recognize_all(sentence, self._trigger_intents):
  File "/usr/local/lib/python3.11/site-packages/hassil/recognize.py", line 406, in recognize_all
    for maybe_match_context in maybe_match_contexts:
  File "/usr/local/lib/python3.11/site-packages/hassil/recognize.py", line 807, in match_expression
    group_contexts = [
  File "/usr/local/lib/python3.11/site-packages/hassil/recognize.py", line 807, in <listcomp>
    group_contexts = [
  File "/usr/local/lib/python3.11/site-packages/hassil/recognize.py", line 826, in match_expression
    raise MissingListError(f"Missing slot list {{{list_ref.list_name}}}")
hassil.recognize.MissingListError: Missing slot list {licht}
My automation YAML looks like this:
alias: VA Test
description: ""
  - platform: conversation
    command:
      - "{licht} auf {zahl}"
      - "{licht} brightness {zahl}"
      - "{licht} bri {zahl}"
    command:
      - Automatik {zustand}
      - auto {zustand}
    command:
      - "{licht} farbe {farbe}"
      - "{licht} color {farbe}"
    command: PZ auf {wert}
    command:
      - "{licht} aus"
      - "{licht} ausschalten "
      - "{licht} deaktivieren"
      - "{licht} pwr off"
      - Turn off {licht}
    command:
      - "{licht} an"
      - "{licht} ein"
      - "{licht} einschalten "
      - "{licht} anschalten "
      - "{licht} aktivieren"
      - "{licht} pwr on"
      - "{licht} power on"
      - Turn on {licht}
    command:
      - PC an
      - PC ein
      - PC hochfahren
      - PC starten
      - "PC einschalten "
      - PC anschalten
      - PC()
    command:
      - Effect set {wert}
    command:
      - MQTT {wert}
      - MQ {wert}
    command:
      - Led solid
      - Leds effect solid
      - Leds solid
      - Led effect solid
    command:
      - Leds strobe {farbe}
      - Led strobe {farbe}
    command:
      - Leds lh {farbe}
      - Led lh {farbe}
      - Leds lighthouse {farbe}
      - Led lighthouse {farbe}
    command:
      - Leds sd {farbe}
      - Led sd {farbe}
      - Leds scan {farbe}
      - Led scan {farbe}
    command:
      - Leds stack
      - Led stack
      - Leds stacking
      - Led stacking
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - lichtAufZahl
        sequence:
          - service: light.turn_on
              brightness_pct: |
                {{trigger.slots.zahl}}
              entity_id: >
                {% if trigger.slots.licht|lower=="iris" %} light.iris {% elif
                trigger.slots.licht|lower == "kugel"%} light.kugel {% elif
                trigger.slots.licht|lower == "stehlampe"%} light.stehlampe {%
                elif trigger.slots.licht|lower == "aaron"%} light.aaron {% elif
                trigger.slots.licht|lower == "leds"%} light.wled {%elif
                trigger.slots.licht|lower == "ez"%} light.esszimmer {%elif
                trigger.slots.licht|lower == "ez1"%} light.esszimmer_1 {%elif
                trigger.slots.licht|lower == "ez2"%} light.esszimmer_2 {%elif
                trigger.slots.licht|lower == "ez1"%} light.esszimmer_3 {%elif
                trigger.slots.licht|lower == "ez1"%} light.esszimmer_4 {%endif%}
      - conditions:
            id:
              - autoZustand
        sequence:
          - choose:
              - conditions:
                  - condition: template
                    value_template: >-
                      {{trigger.slots.zustand=="an" or trigger.slots.zustand
                      =="ein" or trigger.slots.zustand=="aktivieren"}}
                sequence:
                    data: {}
                      entity_id: input_boolean.lichtautomatik
            default:
              - service: input_boolean.turn_off
                data: {}
      - conditions:
            id:
              - lichtFarbe
        sequence:
              color_name: |
                {{trigger.slots.farbe}}
              entity_id: >
      - conditions:
            id:
              - PZ
        sequence:
          - service: number.set_value
              value: |
                {{trigger.slots.wert}}
              entity_id: number.door_personcounter_personenzhler
      - conditions:
            id:
              - LichtAus
        sequence:
          - service: light.turn_off
            data: {}
              entity_id: >
      - conditions:
            id:
              - LichtAn
        sequence:
            data: {}
              entity_id: >
      - conditions:
            id:
              - PCSTART
        sequence:
          - service: switch.turn_on
            data: {}
              entity_id:
                - switch.pc_aaron
                - switch.pc_bildschirme
      - conditions:
            id:
              - EffectSet
        sequence:
          - choose:
              - conditions:
                    value_template: "{{trigger.slots.wert|int==17}}"
                sequence:
                    data: {}
                      entity_id: input_boolean.effekt_17
              - conditions:
                    value_template: "{{trigger.slots.wert|int==18}}"
                sequence:
                    data: {}
                      entity_id: input_boolean.effekt_18
            default:
                data: {}
                  entity_id:
                    - input_boolean.effekt_17
                    - input_boolean.effekt_18
      - conditions:
            id:
              - MQTTwert
        sequence:
          - service: mqtt.publish
              qos: 0
              retain: false
              topic: /sys/LScmd
              payload: |
                {{trigger.slots.wert.upper()}}
      - conditions:
            id:
              - LedSsolid
        sequence:
              effect: Solid
              entity_id: light.wled
      - conditions:
            id:
              - LedsStrobe
        sequence:
          - service: select.select_option
              option: |
                strobe {{trigger.slots.farbe}}
              entity_id: select.wled_voreinstellung
      - conditions:
            id:
              - LedsLH
        sequence:
              option: |
                lighthouse {{trigger.slots.farbe}}
      - conditions:
            id:
              - LedsSD
        sequence:
              option: |
                sd {{trigger.slots.farbe}}
      - conditions:
            id:
              - LedsStacking
        sequence:
              option: stacking
mode: single
So it does error out on the {licht} slot that I used in some of the commands, but not in all the ones I then tried to use.
How could I fix this?
Best regards
Aaron
Why make this so complicated by combining it all in one automation. Just create one automation per sentence.
But would that prevent the error from appearing again?
For me, it’s better to have one big automation than 20 snaller scattered all over the place…
It will make it easier to find out what the issue is. You can start combining them if everything works
I have now separated them and the error is still there when triggering this automation with the command “EZ an”:
alias: Turn On Light
description: ""
    command:
      - "{licht} an"
      - "{licht} ein"
      - "{licht} pwr on"
      - Turn on {licht}
    data: {}
      entity_id: >
        trigger.slots.licht|lower == "stehlampe"%} light.stehlampe {% elif
It also never triggers the automation because of the error
It could be that there are conflicts with the built in sentences. What if you use something like
banana schmetterling {licht}
If i only use “{licht} pwr off” as a trigger, the error still appears although none of the default intents covers “pwr off”
