Strange error/warning in home-assistant.log
I am new to HA and starting with my first installation.
When checking ‘home-assistant.log’ I have 2 messages (error/warning) that I don’t understand:
config $ cat home-assistant.log
2020-04-27 17:57:46 ERROR (MainThread) [frontend.js.latest.202004072] http://192.168.1.4:8123/frontend_latest/app.9eb1a7ca.js:1272:2284 Uncaught TypeError: Cannot read property ‘push’ of null
2020-04-27 18:31:36 WARNING (SyncWorker_11) [homeassistant.util.yaml.loader] YAML file /config/configuration.yaml contains duplicate key “homeassistant”. Check lines 4 and 34.
Here is my configuration.yaml
config $ cat configuration.yaml
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
latitude: 59.372543
longitude: 17.837789
elevation: 41
unit_system: metric
time_zone: Europe/Stockholm
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Text to speech
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
spotify:
client_id: !secret homeassistant_client_id
client_secret: !secret homeassistant_client_secret
  • platform: time_date
    display_options:
    • ‘date_time’
Please read this :
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371/4
Specially point 11 !
OK … sorry I missed this
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
  latitude: 59.372543
  elevation: 41
  unit_system: metric
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
spotify:
  - platform: time_date
    display_options:
      - 'date_time'
Can’t see a second ‘homeassistant’ key on line 34. You don’t have another one in one of your included files ?
I have the first line in secret.yaml … homeassistant:
Remove that and restart HA
OK … I will do that
