ESP32 WROOM, ICS43434 i2s microphone, Max98357 i2s 3W Class D Amplifier, a small speaker, and ESPHome. All is hooked up and works “sometimes”… like I’ve had it working once and after a few mins the log went nuts w/ messages and locked up my browser session.
no errors in the logs for Piper, Whisper or OpenWakeWord.
But, I’m getting some odd behavior in the ESPHome logs.
[13:03:36][D][voice_assistant:395]: State changed from IDLE to IDLE
[13:03:36][D][voice_assistant:401]: Desired state set to IDLE
[13:03:59][D][api:102]: Accepted 192.168.1.250
[13:03:59][W][component:214]: Component api took a long time for an operation (0.06 s).
[13:03:59][W][component:215]: Components should block for at most 20-30ms.
I’m not sure what ‘API’ Voice is trying to connect to?
[voice_assistant:441]: No API client connected
Sometimes I get this:
[13:25:00][D][api.connection:1089]: Home Assistant 2023.11.2 (192.168.1.250): Connected successfully
[13:25:11][D][voice_assistant:502]: Event Type: 0
[13:25:11][E][voice_assistant:624]: Error: stt-stream-failed - speech-to-text failed
[13:25:11][D][voice_assistant:502]: Event Type: 2
[13:25:11][D][voice_assistant:589]: Assist Pipeline ended
[13:25:11][D][light:036]: 'Voice Awake Word Light' Setting:
[13:25:11][D][status_led:050]: 'Voice Awake Word Light': Setting state OFF
ESPHome config
esphome:
friendly_name: shop voice
on_boot:
- priority: -100
then:
- wait_until: api.connected
- delay: 1s
- if:
condition:
switch.is_on: use_wake_word
then:
- voice_assistant.start_continuous:
esp32:
board: esp32dev
framework:
type: esp-idf
version: recommended
# Enable logging
logger:
api:
encryption:
key: "xx"
ota:
password: "xx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Shop-Voice Fallback Hotspot"
password: "K0rTDePNa3nu"
# sck >> bclk
# WS >> lrclk
# SD data pin
i2s_audio:
i2s_lrclk_pin: GPIO22 # MIC-WS SPK- LRC
i2s_bclk_pin: GPIO21 # MIC-SCK SPK- BCLK
microphone:
- platform: i2s_audio
adc_type: external
i2s_din_pin: GPIO17 # SD
pdm: false
speaker:
dac_type: external
i2s_dout_pin: GPIO26 #DIN
mode: mono
voice_assistant:
microphone: mic
use_wake_word: false
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 15.0
speaker: big_speaker
on_listening:
- light.turn_on: led
on_end:
- light.turn_off: led
on_tts_start:
- text_sensor.template.publish:
state: !lambda 'return id(x);'
on_stt_end:
light:
- platform: status_led
name: "Voice Awake Word Light"
pin: GPIO27
disabled_by_default: true
switch:
name: Use wake word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
entity_category: config
on_turn_on:
- lambda: id(assist).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- voice_assistant.stop
- lambda: id(assist).set_use_wake_word(false);
text_sensor:
The REAL strangeness is when this stream finally gets spit out afer a few ESP reboots - it comes so fast it locks up the ESPHome browser session. This all came out in the logs within 3 seconds…
Logs shop-voice.yaml
INFO ESPHome 2023.11.1
INFO Reading configuration /config/esphome/shop-voice.yaml...
INFO Starting log output from shop-voice.local using esphome API
INFO Successfully connected to shop-voice in 0.446s
INFO Successful handshake with shop-voice in 0.137s
[13:21:24][D][voice_assistant:124]: microphone not running
[13:21:24][I][app:102]: ESPHome version 2023.11.1 compiled on Nov 17 2023, 13:03:01
[13:21:24][C][status_led:065]: Status Led Light:
[13:21:24][C][status_led:066]: Pin: GPIO27
[13:21:24][D][voice_assistant:502]: Event Type: 9
[13:21:24][C][wifi:559]: WiFi:
[13:21:24][C][wifi:391]: Local MAC: C8:F0:9E:F3:4D:C4
[13:21:24][C][wifi:396]: SSID: [redacted]
[13:21:24][C][wifi:397]: IP Address: 192.168.1.189
[13:21:24][C][wifi:399]: BSSID: [redacted]
[13:21:24][C][wifi:400]: Hostname: 'shop-voice'
[13:21:24][C][wifi:402]: Signal strength: -52 dB ▂▄▆█
[13:21:24][C][wifi:406]: Channel: 11
[13:21:24][C][wifi:407]: Subnet: 255.255.255.0
[13:21:24][C][wifi:408]: Gateway: 192.168.1.1
[13:21:24][C][wifi:409]: DNS1: 192.168.1.1
[13:21:24][C][wifi:410]: DNS2: 0.0.0.0
[13:21:24][D][voice_assistant:502]: Event Type: 0
[13:21:24][E][voice_assistant:624]: Error: no_wake_word - No wake word detected
[13:21:24][D][voice_assistant:495]: Signaling stop...
[13:21:24][D][voice_assistant:395]: State changed from STARTING_PIPELINE to STOP_MICROPHONE
[13:21:24][D][voice_assistant:401]: Desired state set to IDLE
[13:21:24][D][voice_assistant:395]: State changed from STOP_MICROPHONE to IDLE
[13:21:24][C][logger:416]: Logger:
[13:21:24][C][logger:417]: Level: DEBUG
[13:21:24][C][logger:418]: Log Baud Rate: 115200
[13:21:24][C][logger:420]: Hardware UART: UART0
[13:21:24][D][voice_assistant:502]: Event Type: 2
[13:21:24][D][voice_assistant:589]: Assist Pipeline ended
[13:21:24][D][light:036]: 'Voice Awake Word Light' Setting:
[13:21:24][D][voice_assistant:395]: State changed from IDLE to START_PIPELINE
[13:21:24][D][voice_assistant:401]: Desired state set to START_MICROPHONE
[13:21:24][D][status_led:050]: 'Voice Awake Word Light': Setting state OFF
[13:21:24][D][voice_assistant:206]: Requesting start...
[13:21:24][D][voice_assistant:395]: State changed from START_PIPELINE to STARTING_PIPELINE
[13:21:24][D][voice_assistant:502]: Event Type: 1
[13:21:24][D][voice_assistant:505]: Assist Pipeline running
[13:21:24][C][template.text_sensor:020]: Template Sensor 'STT result'
[13:21:24][C][template.text_sensor:020]: Template Sensor 'TTS response'
[13:21:24][C][template.text_sensor:020]: Template Sensor 'x'
[13:21:24][C][light:103]: Light 'Voice Awake Word Light'
[13:21:24][C][template.switch:068]: Template Switch 'Use wake word'
[13:21:24][C][template.switch:091]: Restore Mode: restore defaults to ON
[13:21:24][C][template.switch:057]: Optimistic: YES
[13:21:24][C][mdns:115]: mDNS:
[13:21:24][C][ota:098]: Address: shop-voice.local:3232
[13:21:24][C][ota:101]: Using Password.
[13:21:24][C][api:139]: API Server:
[13:21:24][C][api:140]: Address: shop-voice.local:6053
[13:21:24][C][api:142]: Using noise encryption: YES
[13:21:25][D][voice_assistant:401]: Desired state set to IDLE
[13:21:25][D][voice_assistant:395]: State changed from STOP_MICROPHONE to IDLE
[13:21:25][D][voice_assistant:502]: Event Type: 2
[13:21:25][D][voice_assistant:589]: Assist Pipeline ended
[13:21:25][D][light:036]: 'Voice Awake Word Light' Setting:
[13:21:25][D][voice_assistant:395]: State changed from IDLE to START_PIPELINE
[13:21:25][D][voice_assistant:401]: Desired state set to START_MICROPHONE
[13:21:25][D][status_led:050]: 'Voice Awake Word Light': Setting state OFF
[13:21:25][D][voice_assistant:495]: Signaling stop...
[13:21:25][D][voice_assistant:124]: microphone not running
[13:21:25][D][voice_assistant:206]: Requesting start...
[13:21:25][D][voice_assistant:395]: State changed from START_PIPELINE to STARTING_PIPELINE
[13:21:25][D][voice_assistant:502]: Event Type: 1
[13:21:25][D][voice_assistant:505]: Assist Pipeline running
[13:21:25][D][voice_assistant:502]: Event Type: 9
[13:21:25][D][voice_assistant:502]: Event Type: 0
[13:21:25][E][voice_assistant:624]: Error: no_wake_word - No wake word detected
[13:21:25][D][voice_assistant:395]: State changed from STARTING_PIPELINE to STOP_MICROPHONE
[13:21:26][D][voice_assistant:124]: microphone not running
[13:21:26][D][voice_assistant:206]: Requesting start...
[13:21:26][D][voice_assistant:395]: State changed from START_PIPELINE to STARTING_PIPELINE
[13:21:26][D][voice_assistant:502]: Event Type: 1
[13:21:26][D][voice_assistant:505]: Assist Pipeline running
[13:21:26][D][voice_assistant:502]: Event Type: 9
[13:21:26][D][voice_assistant:502]: Event Type: 0
[13:21:26][E][voice_assistant:624]: Error: no_wake_word - No wake word detected
[13:21:26][D][voice_assistant:495]: Signaling stop...
So I just rebooted the ESP again (no changes), and its working and I got this after saying “Hey Jarvis, turn on toolbox light”:
[13:39:09][D][voice_assistant:502]: Event Type: 10
[13:39:09][D][voice_assistant:511]: Wake word detected
[13:39:09][D][voice_assistant:502]: Event Type: 3
[13:39:09][D][voice_assistant:516]: STT started
[13:39:09][D][light:036]: 'Voice Awake Word Light' Setting:
[13:39:09][D][light:047]: State: ON
[13:39:09][D][status_led:050]: 'Voice Awake Word Light': Setting state ON
[13:39:10][D][voice_assistant:502]: Event Type: 11
[13:39:10][D][voice_assistant:643]: Starting STT by VAD
[13:39:12][D][voice_assistant:502]: Event Type: 12
[13:39:12][D][voice_assistant:647]: STT by VAD end
[13:39:28][D][voice_assistant:502]: Event Type: 4
[13:39:28][D][voice_assistant:395]: State changed from STREAMING_MICROPHONE to STOP_MICROPHONE
[13:39:28][D][voice_assistant:401]: Desired state set to AWAITING_RESPONSE
[13:39:28][D][voice_assistant:531]: Speech recognised as: " Turn toolbox on."
[13:39:28][D][text_sensor:064]: 'STT result': Sending state ' Turn toolbox on.'
[13:39:28][D][voice_assistant:395]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[13:39:28][D][esp-idf:000]: I (236957) I2S: DMA queue destroyed
[13:39:28][D][voice_assistant:502]: Event Type: 5
[13:39:28][D][voice_assistant:536]: Intent started
[13:39:28][D][voice_assistant:395]: State changed from STOPPING_MICROPHONE to AWAITING_RESPONSE
[13:39:28][D][voice_assistant:502]: Event Type: 6
[13:39:28][D][voice_assistant:502]: Event Type: 7
[13:39:28][D][voice_assistant:559]: Response: "Turned on switch"
[13:39:28][D][text_sensor:064]: 'TTS response': Sending state 'Turned on switch'
[13:39:28][D][voice_assistant:502]: Event Type: 8
[13:39:28][D][voice_assistant:577]: Response URL: "https://rc2o77cp1gdll61vz9yjzvjd63kt5fab.ui.nabu.casa/api/tts_proxy/093290dcda7b2989879ced0ee701d7978ed0c34a_en-us_fdd41fd0ec_tts.piper.raw"
[13:39:28][D][voice_assistant:395]: State changed from AWAITING_RESPONSE to STREAMING_RESPONSE
[13:39:28][D][voice_assistant:401]: Desired state set to STREAMING_RESPONSE
[13:39:28][D][i2s_audio.speaker:161]: Starting I2S Audio Speaker
[13:39:28][D][voice_assistant:502]: Event Type: 2
[13:39:28][D][voice_assistant:589]: Assist Pipeline ended
[13:39:28][D][light:036]: 'Voice Awake Word Light' Setting:
[13:39:28][D][light:047]: State: OFF
[13:39:28][D][i2s_audio.speaker:164]: Started I2S Audio Speaker
[13:39:28][D][status_led:050]: 'Voice Awake Word Light': Setting state OFF
[13:39:28][D][voice_assistant:502]: Event Type: 98
[13:39:29][D][voice_assistant:502]: Event Type: 99
[13:39:29][D][voice_assistant:395]: State changed from STREAMING_RESPONSE to RESPONSE_FINISHED
[13:39:29][D][voice_assistant:401]: Desired state set to IDLE
[13:39:29][D][voice_assistant:395]: State changed from RESPONSE_FINISHED to IDLE
[13:39:29][D][voice_assistant:395]: State changed from IDLE to START_PIPELINE
[13:39:29][D][voice_assistant:401]: Desired state set to START_MICROPHONE
[13:39:29][D][voice_assistant:124]: microphone not running
[13:39:29][D][voice_assistant:206]: Requesting start...
[13:39:29][D][voice_assistant:395]: State changed from START_PIPELINE to STARTING_PIPELINE
[13:39:29][D][i2s_audio.speaker:167]: Stopping I2S Audio Speaker
[13:39:29][D][voice_assistant:416]: Client started, streaming microphone
[13:39:29][D][voice_assistant:395]: State changed from STARTING_PIPELINE to START_MICROPHONE
[13:39:29][D][voice_assistant:401]: Desired state set to STREAMING_MICROPHONE
[13:39:29][D][voice_assistant:159]: Starting Microphone
[13:39:29][D][voice_assistant:395]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[13:39:29][D][i2s_audio.speaker:178]: Stopped I2S Audio Speaker
[13:39:29][D][esp-idf:000]: I (238584) I2S: DMA Malloc info, datalen=blocksize=1024, dma_buf_count=4
[13:39:29][D][voice_assistant:502]: Event Type: 1
[13:39:29][D][voice_assistant:505]: Assist Pipeline running
[13:39:29][D][voice_assistant:395]: State changed from STARTING_MICROPHONE to STREAMING_MICROPHONE
[13:39:44][D][voice_assistant:502]: Event Type: 0
[13:39:44][D][voice_assistant:502]: Event Type: 2
[13:39:44][D][voice_assistant:589]: Assist Pipeline ended
[13:39:44][D][voice_assistant:395]: State changed from STREAMING_MICROPHONE to IDLE
[13:39:44][D][voice_assistant:401]: Desired state set to IDLE
[13:39:44][D][light:036]: 'Voice Awake Word Light' Setting:
[13:39:44][D][voice_assistant:395]: State changed from IDLE to START_PIPELINE
[13:39:44][D][voice_assistant:401]: Desired state set to START_MICROPHONE
[13:39:44][D][status_led:050]: 'Voice Awake Word Light': Setting state OFF
[13:39:44][D][voice_assistant:206]: Requesting start...
[13:39:44][D][voice_assistant:395]: State changed from START_PIPELINE to STARTING_PIPELINE
[13:39:44][D][voice_assistant:416]: Client started, streaming microphone
[13:39:44][D][voice_assistant:395]: State changed from STARTING_PIPELINE to
So, after 8-10 ESP reboots, it worked and behaved… its painfully slow, but the light went on. From this
[13:43:59][D][voice_assistant:511]: Wake word detected
to this
[13:44:18][D][voice_assistant:531]: Speech recognised as: " turn toolbox on."
is 19 seconds…
There are so many moving parts to this I’m not even sure where to begin!!!
Jeff
