Hi everyone,
thanks for the great work at this point ! And sorry for my bad english speeking brain ![]()
I have configured a Hue-Bridge and integrated it normally in HA.
Everything works perfect, expected a few “cheap” Livarnolux zigbee led stipes I bought at Lidl in Germany.
When I turn it on via HA, first of all you see a bright flash, and than it turns to the right brightnes.
Also when you change the brightness it will first flash and turn than to the right setting.
If i use a automation, that fades the light for about 5 minutes, the strip flashes everytime, the brightnes is changed. 0%, flash, 1%, flash, 2%, flash and so on.
When I dim up or down the Light in the Hue or Hue Essentials app, fading works normally without lightflashs.
Is there maybe any yaml switch for turning off this “flashing feature” in HA ?
Thanks a lot everyone
