I have all of my light and switches turned off, then all the sudden the system just turn everything on, but only in the UI, the lamps does not physically turns on, it just shows them as turned on.
Some of them get turned off automatically after some time.
Anyone has any idea what this could be? I don’t have anything in automations, or node-red that could cause this.
You have probably not specified an entity_id somewhere you should have (or HA can’t find the entity as you have misspelled it). So all entities are switched instead.
