Strange issue "not iterable"
Hi guys,
Suddenly my instance (HAssOS on tinkerboard) doesnt check config or is able to reboot…
any techies around to hint me in the right direction??
Logger: homeassistant.components.websocket_api.http.connection
Source: helpers/config_validation.py:813
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 11:07:19 (1 occurrences)
Last logged: 11:07:19
[2806444408] argument of type 'NoneType' is not iterable
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1738, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1775, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 691, in async_handle_core_service
    errors = await conf_util.async_check_ha_config_file(hass)
  File "/usr/src/homeassistant/homeassistant/config.py", line 929, in async_check_ha_config_file
    res = await check_config.async_check_ha_config_file(hass)
  File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 233, in async_check_ha_config_file
    p_validated = platform_schema(p_validated)
  File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 232, in __call__
    return self._exec((Schema(val) for val in self.validators), v)
  File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 351, in _exec
    v = func(v)
  File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable
    return schema(data)
  File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 387, in validate_mapping
    cval = cvalue(key_path, value)
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 541, in verify
    return cast(dict, schema(value))
  File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 229, in _run
    return self._exec(self._compiled, value, path)
  File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 353, in _exec
    v = func(path, v)
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 813, in validator
    if key in config:
TypeError: argument of type 'NoneType' is not iterable
Any help would be highly appreciated! :slight_smile:
What is the last thing you changed?
undo it…
no code changes, just updates…
Which update?
You should submit an issue to the update.
Hi!
Did you find a solution to your issue? I seem ti have the same issue and i don’t have a clue to what i could be?!
now it’s gone, dont know what made it go away… sorry man, cant really help
