SFreeman87
(S Freeman87)
1
I’ve been having an odd issue I can’t seem to resolve or find a fix for. Essentially I installed SSH via the Add-ons which works fine.
I can ping google.com and get a response with no issues.
However when trying to use wget -O - https://get.hacs.xyz | bash - (for instance)
I’ll get a network unreachable error. Does anyone have any ideas what could be causing this? I have attached a photo for reference
Kind Regards,
francisp
(Francis)
2
It tries to reach github over ipv6, and can’t.
Disable ipv6 and try again.
or use
wget --inet4-only -O - https://get.hacs.xyz | bash -
I really hoped that would work! I tried your inet4 only approach and got the following message.
I then disabled ipv6 via System - Network and tried the original install line and yours again and no bueno!
Really confused on this one
C:\Users\Omega>nslookup raw.githubusercontent.com
Server: cloudmesh.home
Address: 192.168.20.1
Non-authoritative answer:
Addresses: 2606:50c0:8001::154
2606:50c0:8003::154
2606:50c0:8002::154
2606:50c0:8000::154
185.199.111.133
185.199.109.133
185.199.110.133
185.199.108.133
francisp
(Francis)
7
Try the same on your HA Box
Yeah this doesn’t look right. IPv6 is disabled… BTW it’s running in Vmware if that makes a difference.
BTW thank you for trying to help, muchly appreciated!
francisp
(Francis)
10
Try to set your HA DNS-servers to this
SFreeman87
(S Freeman87)
11
Unfortunately all that did was make me loose internet access…
