The last 24 hours I am messing with HA (trying to add some integrations and addons) and probably I changed something that I shouldn’t.
Since May I have connected some meross switches in HA with MQTT in local network and they working fine. Today although they are still connected with HA and everything is working the switches are blinking red as if they are not connected.
Does anyone understand from the below logs what is the problem?
logins: []
anonymous: false
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
1629907721: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907721: Socket error on client <unknown>, disconnecting.
1629907721: New connection from 192.168.1.47 on port 8883.
1629907721: Client connection from 192.168.1.49 failed: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher.
1629907721: New connection from 192.168.1.48 on port 8883.
1629907722: New connection from 192.168.1.51 on port 8883.
1629907722: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907722: Socket error on client <unknown>, disconnecting.
1629907723: Client connection from 192.168.1.53 failed: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher.
1629907724: New connection from 192.168.1.50 on port 8883.
1629907724: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907724: Socket error on client <unknown>, disconnecting.
1629907725: New connection from 192.168.1.52 on port 8883.
1629907725: New connection from 192.168.1.49 on port 8883.
1629907725: New connection from 192.168.1.47 on port 8883.
1629907725: New connection from 192.168.1.48 on port 8883.
1629907725: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907725: Socket error on client <unknown>, disconnecting.
1629907726: New connection from 192.168.1.51 on port 8883.
1629907726: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907726: Socket error on client <unknown>, disconnecting.
1629907727: New connection from 192.168.1.53 on port 8883.
1629907727: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907727: Socket error on client <unknown>, disconnecting.
1629907728: New connection from 192.168.1.50 on port 8883.
1629907728: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907728: Socket error on client <unknown>, disconnecting.
1629907729: New connection from 192.168.1.52 on port 8883.
1629907729: New connection from 192.168.1.49 on port 8883.
1629907729: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907729: Socket error on client <unknown>, disconnecting.
1629907729: New connection from 192.168.1.47 on port 8883.
1629907729: New connection from 192.168.1.48 on port 8883.
1629907730: New connection from 192.168.1.51 on port 8883.
1629907730: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907730: Socket error on client <unknown>, disconnecting.
1629907731: New connection from 192.168.1.53 on port 8883.
1629907731: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907731: Socket error on client <unknown>, disconnecting.
1629907732: New connection from 192.168.1.50 on port 8883.
1629907732: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907732: Socket error on client <unknown>, disconnecting.
1629907733: New connection from 192.168.1.52 on port 8883.
1629907733: New connection from 192.168.1.49 on port 8883.
1629907733: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907733: Socket error on client <unknown>, disconnecting.
1629907733: New connection from 192.168.1.47 on port 8883.
1629907733: New connection from 192.168.1.48 on port 8883.
1629907734: New connection from 192.168.1.51 on port 8883.
1629907734: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907734: Socket error on client <unknown>, disconnecting.
1629907735: New connection from 192.168.1.53 on port 8883.
1629907735: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907735: Socket error on client <unknown>, disconnecting.
1629907736: New connection from 192.168.1.50 on port 8883.
1629907736: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907736: Socket error on client <unknown>, disconnecting.
1629907737: New connection from 192.168.1.52 on port 8883.
1629907737: New connection from 192.168.1.49 on port 8883.
1629907737: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907737: Socket error on client <unknown>, disconnecting.
1629907737: New connection from 192.168.1.47 on port 8883.
1629907737: New connection from 192.168.1.48 on port 8883.
1629907738: New connection from 192.168.1.51 on port 8883.
1629907738: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907738: Socket error on client <unknown>, disconnecting.
1629907739: New connection from 192.168.1.53 on port 8883.
1629907739: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907739: Socket error on client <unknown>, disconnecting.
1629907740: New connection from 192.168.1.50 on port 8883.
1629907740: OpenSSL Error: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
1629907740: Socket error on client <unknown>, disconnecting.
