Omerdagan
(Omerdagan)
1
I’ve been trying to configure automation for my themes,
I can set them manually, but the automation is not working at all.
- alias: Automatic Theme Change
- platform: homeassistant
event: start
- platform: state
entity_id: sun.sun
to: above_horizon
- platform: state
entity_id: sun.sun
to: below_horizon
- service_template: frontend.set_theme
data_template:
{% if states.sun.sun.state == "above_horizon" %}
clear
{% else %}
night
{% endif %}
frontend:
themes: !include themes.yaml
finity
2
The first thing is that you need to make sure you post your code properly formatted for the forum.
But by wading thru your un-formatted code I think I see the issue. try this:
event: start
- platform: state
entity_id: sun.sun
to: 'above_horizon'
- platform: state
entity_id: sun.sun
to: 'below_horizon'
- service: frontend.set_theme
data_template: >
name:
clear
{% else %}
night
{% endif %}
Omerdagan
(Omerdagan)
3
thank you for your reply, i have it correctly formatted now. after trying your fix,HA gives me an error and the automation don’t appear.
finity
4
crap! I see the error…I think…try this:
event: start
- platform: state
entity_id: sun.sun
to: 'above_horizon'
- platform: state
entity_id: sun.sun
to: 'below_horizon'
data_template:
clear
{% else %}
night
{% endif %}
if that doesn’t work then tell me what the error says.
QbaF
(Qba F)
5
General question:
According to warning, should it be
or
if states('sun.sun') ==
