My goal is to start streaming camera video to mibox from home assistant.
I have tried many ways, but I still can’t find the perfect solution.
I put the chromecast built-in application on the mibox. I add integration to the home assistant.
Create a Script
sequence:
- service: camera.play_stream
media_player: media_player.mibox
entity_id: camera.dahua1
mode: single
alias: Show camera on TV
icon: mdi: webcam
Does not work!
I try in another way.
I want to run VLC player on mibox and run the file there. VLC launches without problems. But how to run the required file on it (url file with rtsp stream address) - I don’t know. All the same, you still have to press the launch with the joystick.
sequence:
- service: media_player.select_source
entity_id: media_player.mibox
source: VLC
mode: single
alias: Show camera on VLC TV
How can I open the file here now?
I try to use the thread launch directly.
sequence:
- service: media_player.play_media
media_content_id: rtsp: // *****: ********@192.168.1.126: 554 / h264Preview_01_main
media_content_type: video
mode: single
alias: Show camera on TV 2
Does not work!
Please tell me where to look.
P.S. and by the way, can anyone know how to turn on mibox after it falls asleep? He turns off with the home assistant well. And you have to turn it on only from the remote control. I tried ADB in developer mode, it does not work.
Really few people have such a task?
I just want to receive streaming video to my TV during a call, when someone comes. So that the camera immediately starts up on the TV.
hi
i installed hassio android on my mibox and i made a default lovelace interface with my cams only.
(you go in app setting and choose default lovelace panel)
u could try launch one in your sequence.
download hassio.apk put it somewhere (usb key, samba…), install it on mibox, with a file explorer.
where to download an apk:
found on google: Free Online APK Downloader | AppsApk.com]
where to find a file explorer:
on the playstore. i’m using “x-plore”
Thanks. I searched the app store. Not found. And Google did not suggest anything. Now I will follow this path. Install apk.
And regarding the launch of the camera broadcast on mibox, I had a solution. I created url file rtsp stream and ran it in x-plore.
It is not difficult, but it is inconvenient.
But the most important thing that I would like to know is the code by which it is possible to select an application and run such a file in it.
Like this:
source: VLC
# Nice. VLC in MiBox is open.
# Now I want to open my file in VLC. How to do it? What code should I write?
Thank you very much for the answer.
I installed home assistant apk and launched it on mibox using a script that opens the camera window right away.
Everything worked out. Not the best option, but still good.
I also made a script that, using the remote control keys through the remote ir, passes through it and opens the desired file with the rtsp stream.
It also works and is also not ideal.
But with vls, I still did not figure out how and where to enter commands. And what command exactly, what to start the rtsp stream on the VLC player on the MiBox.
And everything that concerns the VLC player as a virtual home assistant player is not like that. Because I need to run the video not on the home assistant, but on mibox.
And I used one more method and it turned out to be the simplest and most suitable.
Launching stream of camera object on chromecast mibox. Everything is simple and everything works.
This is exactly where I started, just two media players appeared in the home assistant. One api, second chromecast. I just chose the wrong player in the first version.
