has anyone got audio working through the camera stream?
Hey did you have any luck configuring jpg url for the Wyze cams? If yes do you mind sharing the format of it?
I had to use the same config as yourself. I changed the second stream to H.264 the same as the primary stream however at a lower resolution.
Is there anyone out there using SV3C PoE 1080p bullet cams and got it working ok?
Either direct or via BlueIris I am not fussy!
I didn’t have any luck getting a still image. I just tell it in config to use the live stream for the image.
About the errors that show up hundreds
Of times regarding missing references or whatever. They’re still there. But the cams seem to be working despite. 15s delay
I’m using SV3C PoE 1080p cam and it works fine. I’m using mine direct. HA is installed using docker. The PTZ cam from SV3C on the other hand is giving me fits with the motion but the picture is great.
camera:
- platform: generic
still_image_url: “http://camera_ip/mjpeg/snap.cgi?chn=0”
stream_source: “rtsp://user:pw@camera_ip:554/live/ch0”
My camera is a Happyegg chinese Wifi IP CAM. But it’s not available anymore.
I used Onvifer on my Android to figure out the still image and the video source. And now it is working great with this new component in Hassio. Before I used another component which gave very choppy playback.
Any chance you should share you yaml for it?
Here are my entries:
camera: - platform: ffmpeg input: !secret drivewaycamurl name: Driveway - platform: ffmpeg input: !secret backyardcamurl name: Backyard - platform: ffmpeg input: !secret southstallcamurl name: South Stalls - platform: ffmpeg input: !secret northstallcamurl name: North Stalls - platform: ffmpeg input: !secret pasturecamurl name: Pasture
Format of the URL is like this:
rtsp://admin:[email protected]/stream0
i have same issue, you solved it?
same issue, someone solved it?
What have you tried already? Share your log and yaml here to troubleshoot
I have mine working directly, grabbing the rtsp stream.
Been trying to get them working through motioneye as well, but no luck yet.
Can you share your HA config for that?
I can’t succeed
Do we know what the error Error demuxing stream: No dts in packet
indicates?
Same camera, dafang hack
same configuration.yaml
stream:
camera:
- platform: generic
still_image_url: https://192.168.x.x/cgi-bin/currentpic.cgi
stream_source: rtsp://192.168.x.x:8554/unicast
verify_ssl: false
username: root
password: xxx
authentication: basic
scan_interval: 5
same automation.yaml
alias: mandamos video a cast
xxx
- data:
entity_id: camera.camara_entrada
media_player: media_player.kiii_pro
service: camera.play_stream
i try with dev-service too.
And same issue, It seems it gonna work but black screen and i never see anything
Log dont show nothing.
I think is configuration of video and audio of Dafang, someone who has managed to get this camera working can share their video settings??
I have zoneminder which exposes all the cameras.
I have tried the stream component but it doesn’t work
Here’s a working example on hassio v.0.94.2:
- platform: generic
still_image_url: http://admin:[email protected]:80/cgi-bin/currentpic.cgi
stream_source: rtsp://admin:[email protected]:554/ch0.h264
verify_ssl: false
username: admin
password: pw
D-Link DCS-5030L
The following configuration works for me. YMMV
camera:
- platform: mjpeg
still_image_url: "http://i.j.k.l/image/jpeg.cgi"
mjpeg_url: "http://i.j.k.l/mjpeg.cgi"
username: !secret D-Link00username
password: !secret D-Link00password
