Nevermind about the above post. I figured out I had IP conflicts on my network. I had assigned the same IP address to one of my TVs and to that particular camera.
EDIT: itās working now! The change I made was to change the subtype from 0 to 1.
I am using a Dahua IP camera and I have tried many things to get it to work. I have confirmed with VLC that the camera is serving an RTSP stream. I have also confirmed with a web browser that the still image URL works.
- platform: generic
still_image_url: "http://192.168.1.X/cgi-bin/snapshot.cgi"
stream_source: "rtsp://username:[email protected]:554/cam/realmonitor?channel=1&subtype=00"
username: !secret camera_username
password: !secret camera_password
authentication: basic
verify_ssl: false
I have tried all combinations of āauthentication: basicā, āauthentication: digestā, and āverify_ssl: falseā.
In home assistant, clicking into the camera.test entity just shows the spinning āwaitingā icon with a gray background.
There are no error logs being printed in the home assistant logs. Any helpful suggestions would be appreciated.
I have spend hours today trying to work out why my stream werenāt workingā¦ I wish I had read this comment earlier
I switched to 265+ a few days agoā¦ any idea if 265/265+ will be supported please?
No matter what I try I canāt get my rtsp feed to work. It works in any other app like vlc but in HA no go. Very frustrating.
My config is
camera 3:
- platform: generic
still_image_url: "https://www.pinclipart.com/picdir/big/4-49346_camera-png-clipart-photographic-film-clip-art-camera.png"
stream_source: "rtsp://192.168.0.29:554/11"
verify_ssl: False
May I ask why you are putting the /11 at the end of the url?
Thatās what my IP camera gave. I removed it but still canāt get video. url works in vlc without the /11
Iāve seen it asked a bunch of times above, but anyone know how to get audio out of the rtsp stream? Donāt need an elegant solution, just need something that works.
Hi greg, what is your foscam config for streaming? Mine doesnāt work, vlc is fine
Here is what I have. Its been a long time, but I think I changed the ports on all of them to 88 for consistency. I believe one of them used a different port by default for some reason so you may have to play around:
- platform: foscam
ip: '<ip address>'
port: 88
I have three cameras and set the user/pass the same.
- FI9821P (x2)
- C1
I can stream OK from the frontend (its very delayed), but I have never been able to get the streams to show on my Google display. It just says Smart Home Camera and doesnt do anything.
I may dump Foscams for Wyze soon.
Iām having trouble getting my live camera stream to work with Blue Iris. I think there is some issue with HA logging into BI, although Iām not sure if itās my issue or something else. I currently have the mjpeg camera setup and working. That config looks like this and has no issues. I can see in blue iris that user has connected and successfully logged in and is viewing the camera:
- platform: mjpeg
mjpeg_url: http://192.168.*.*/mjpg/GarageRight
username: user
password: password
When I try creating a generic camera with stream_source config it looks like this:
- platform: generic
still_image_url: 'http://192.168.*.*/image/FrontDoor'
stream_source: 'http://192.168.*.*/h264/FrontDoor/temp.m3u8'
name: Front Door Test
username: user
password: pass
But it will not work. When I look in BI connections, I see that it does try to connect but never gets past the āloginā stage, shows no username, and the stream just spins:
If I configure BI to allow connections from HA with admin privileges, it will work (but I do not want to allow that):
Has anyone else run into this? Or do I just have my configuration incorrect? Thanks for any help.
For those struggling with RTSP on Dahua / VIP Vision try using ONVIF.
Background I have a Dahua (rebranded VIP Vision in Australia) 4MP mini-dome running on 192.168.0.200. Iāve tried every recommendation and permutation listed here for the RTSP stream, none work. The stream function is very buggy and throwing up a heap of errors for me.
Solution. After lots of mucking about I switched to ONVIF. I can only assume that there is something in the stream module which is not working with the Dahua RTSP ffmpg but does work with ONVIF.
Do note that ONVIF seems to have a pretty hefty lag though - up to 30 seconds.
#ONVIF stream from 192.168.0.200
- platform: onvif
host: 192.168.0.200
username: !secret cam1_usr
password: !secret cam1_pwd
port: 80
on the Lovelace side.
- type: picture-entity
title: Test
entity: camera.t_cam2
camera_view: live
Iāve run into the same issue. Give this a shotā¦ works fine for my Blue Iris cameras.
- platform: generic
still_image_url: 'http://USERNAME:[email protected].*.*/image/FrontDoor'
stream_source: 'http://USERNAME:[email protected].*.*/h264/FrontDoor/temp.m3u8'
Would love to understand why the documented method of authentication doesnāt work as intended though.
You can disable the need to embed username and password values by disabling authentication for this IP address in your Blue Iris webserver. The trick is to prefix the IP address of your Home Assistant server with a caret ā^ā in the list of IP addresses, i.e.: ^192.168.1.xxx
I have tried BlueIris stream_source and Dahua stream_source.
BlueIris stream_source is very laggy and crashes in 2 second.
Dahua Iris stream_source has better quality but crashes in around 10 seconds.
I have used BlueIris mjpeg before, It was very stable.
Is it possible to achieve reliable streaming using BlueIris or Dahua?
edit: disconnect mainly happens during streaming to tv
This works. Is there a way to use the !secrets file with this configuration?
Yes I was able to get it to work this way, but when I do that it connects via the Admin BI user, which I didnāt want.
Of course!
secrets.yaml
cam_front_door_still_image_url: 'http://USERNAME:[email protected].*.*/image/FrontDoor'
cam_front_door_stream_source: 'http://USERNAME:[email protected].*.*/h264/FrontDoor/temp.m3u8'
cameras.yaml
- platform: generic
still_image_url: !secret cam_front_door_still_image_url
stream_source: !secret cam_front_door_stream_source
Ahh that makes sense. I wasnāt sure how to integrate it into the config. Thanks for your help I will try it out.
Has anyone been able to get streaming working using NVR and a Flex camera?
I have tried using the RTSP url as suggested in post.
stream_source: "rtsp://10.0.10.6:7447/5c35744ae4b00e065c24865d_1"
I pulled the URL from the NVR listing for the RTSP setting.
I figured out the RTSP NVR issue. I had to use my local IP not the one provided by NVR outside app.
Has anyone figured out a solution for motion detection on Unifi cameras?
