I’ve got a problem with the stream component. I didn’t notice when exactly it happened to me but now I have a problem with it.
The log file says:
2019-11-18 22:48:33 ERROR (MainThread) [homeassistant.setup] Error during setup of component stream
File "/srv/homeassistant_venv_3.7/lib/python3.7/site-packages/homeassistant/setup.py", line 172, in _async_setup_component
hass, processed_config
File "/srv/homeassistant_venv_3.7/lib/python3.7/site-packages/homeassistant/components/stream/__init__.py", line 107, in async_setup
from .recorder import async_setup_recorder
File "/srv/homeassistant_venv_3.7/lib/python3.7/site-packages/homeassistant/components/stream/recorder.py", line 6, in <module>
import av
File "/srv/homeassistant_venv_3.7/lib/python3.7/site-packages/av/__init__.py", line 9, in <module>
from av._core import time_base, pyav_version as __version__
ImportError: libavutil.so.55: cannot open shared object file: No such file or directory
All required packages from this page are installed.
There are required libraries installed in the system but they are newer
ls /usr/lib/arm-linux-gnueabihf/libav*
/usr/lib/arm-linux-gnueabihf/libavahi-client.so.3 /usr/lib/arm-linux-gnueabihf/libavfilter.a
/usr/lib/arm-linux-gnueabihf/libavahi-client.so.3.2.9 /usr/lib/arm-linux-gnueabihf/libavfilter.so
/usr/lib/arm-linux-gnueabihf/libavahi-common.so.3 /usr/lib/arm-linux-gnueabihf/libavfilter.so.7
/usr/lib/arm-linux-gnueabihf/libavahi-common.so.3.5.3 /usr/lib/arm-linux-gnueabihf/libavfilter.so.7.40.101
/usr/lib/arm-linux-gnueabihf/libavahi-core.so.7 /usr/lib/arm-linux-gnueabihf/libavformat.a
/usr/lib/arm-linux-gnueabihf/libavahi-core.so.7.0.2 /usr/lib/arm-linux-gnueabihf/libavformat.so
/usr/lib/arm-linux-gnueabihf/libavc1394.so.0 /usr/lib/arm-linux-gnueabihf/libavformat.so.58
/usr/lib/arm-linux-gnueabihf/libavc1394.so.0.3.0 /usr/lib/arm-linux-gnueabihf/libavformat.so.58.20.100
/usr/lib/arm-linux-gnueabihf/libavcodec.a /usr/lib/arm-linux-gnueabihf/libavresample.a
/usr/lib/arm-linux-gnueabihf/libavcodec.so /usr/lib/arm-linux-gnueabihf/libavresample.so
/usr/lib/arm-linux-gnueabihf/libavcodec.so.58 /usr/lib/arm-linux-gnueabihf/libavresample.so.4
/usr/lib/arm-linux-gnueabihf/libavcodec.so.58.35.100 /usr/lib/arm-linux-gnueabihf/libavresample.so.4.0.0
/usr/lib/arm-linux-gnueabihf/libavdevice.a /usr/lib/arm-linux-gnueabihf/libavutil.a
/usr/lib/arm-linux-gnueabihf/libavdevice.so /usr/lib/arm-linux-gnueabihf/libavutil.so
/usr/lib/arm-linux-gnueabihf/libavdevice.so.58 /usr/lib/arm-linux-gnueabihf/libavutil.so.56
/usr/lib/arm-linux-gnueabihf/libavdevice.so.58.5.100 /usr/lib/arm-linux-gnueabihf/libavutil.so.56.22.100
I was trying to cheat and make lower version symlinks to existing libs but at the end it still wants to have exactly required version. Does anyone have an idea how to fix it ? Thank you.
P.S. Version of Home Assistant is 0.101.3
