when open VLC and playing the stream from my camera, it’s looking very good.
when open the stream in HA it very chanky .
is there something to do?
my config is
What’s the resolution of your camera? Also where do you run VLC from?
Video feeds are quite CPU hungry so “pulling” the stream from the camera and replaying it from the Pi might be too much if it’s a high res camera?
I personally use the high res for recording and the 2nd channel (low res) for streaming
No, it didn’t change match.
it’s start bad (10 frame ps) but in 3 sec it’s stops all together.
my camera is yi home camera 1080p with yi-hack-v4
is there something to do here?
Refael
I had a similar problem with my amcrest cameras. This is when I would click on the “thumbnail” picture in the frontend which would open the stream in a larger window. It would take 7 to 10 seconds for it to actually start playing, and then after 30 seconds it would stop. This was with a relatively recent checkout of the HA dev branch. But I just updated it and tried again, and now it is working fine! I think this has something to do with PR #22338, which appears to be scheduled for 0.90.2.
