I used to have an automation that cast a generic camera stream to a Google Home display when motion was detected. It’s been working for ages.
In a recent update it has stopped working.
I did have my cameras manually configured in configuration.yaml but have disabled this as I gather they are now automicaly detected. The cameras are still working fine but stream does not.
If I have the stream: entry in configuration.yaml then I get the following error on a restart which looks like a bug to me.
Any help appreciated. Thanks. Rob.
Logger: homeassistant.setup
Source: components/stream/recorder.py:9
First occurred: 14:54:53 (1 occurrences)
Last logged: 14:54:53
Error during setup of component stream
File “/usr/src/homeassistant/homeassistant/setup.py”, line 235, in _async_setup_component
result = await task
File “/usr/src/homeassistant/homeassistant/components/stream/init.py”, line 216, in async_setup
from .recorder import async_setup_recorder
File “/usr/src/homeassistant/homeassistant/components/stream/recorder.py”, line 9, in
import av
File “/usr/local/lib/python3.10/site-packages/av/init.py”, line 20, in
from av import logging
ImportError: Error loading shared library libXfixes-d5f50c54.so.3.1.0: Exec format error (needed by /usr/local/lib/python3.10/site-packages/av/…/ha_av.libs/libva-x11-9a51a992.so.2.1400.0)
Home Assistant 2022.8.6
Supervisor 2022.08.3
Operating System 8.5
