Now, when I ask Google to show me the camera, I get a Not connected error about Nabu Casa. I would like to be able to stream without Nabu Casa. Is that possible with Home Assistant?
Hi @godinperson did you manage to resolve the issue? I am having the same problem. I have h264 enabled in blue iris and am using the standard blue iris integration. I have also enabled the stream integration in the config.yaml file.
Thanks for the answer. I wrote in the configuration.yaml internal_url file: “https://192.168.1.110:8125” but I still get a Not connected error about Nabu Casa on my Google Hub. What’s in your internal_url, IP or domain name, for example "https: //homeassistant.local: 8125 “or” https://192.168.1.110:8125 "?
I specified internal_url: “https://xxx.duckdns.org:8125”, but I still get a Not connected error about Nabu Casa on my Google Hub. Although I normally visit “https://xxx.duckdns.org:8125” on the homeassistant management page, the certificate is valid. The camera in the Google Hub is visible, but there is no broadcast, although the camera displays the image normally on the homeassistant control page. I don’t know what to do (.
