I’m running a HA Container on Docker in Synology. It is a DS1621+ with plenty of ram (32gB).
Currently I use Synology Video Station as NVR and it works well with HA, including streaming. Camera’s are Unifi G3 Flex and Doorbird D101.
I want to switch to frigate (Docker, on same Synology), but when I set this up I keep seeing that the stream buffers on live view. Every 2-3 sec the stream stops for a second and then continues. (Tested on Unifi G3 Flex)
The stream from frigate works fine when I connect with VLC. Also, the stream which is recorded by frigate works fine.CPU and ram usage of the Synology host are (very) low.
What could be the problem and how could I solve this?
