Streamline-Card not getting any Template
Hey,
I’ve tried some days now to get the Streamline-Card templates working
When entering the template into dashboard raw all works, when entering in a YAML the template is not found. I have no more idea what I’m missing, any hint?
I have in /homeassistant/configuration.yaml:
# Includes
scene: !include scenes.yaml
streamline_templates: !include_dir_named streamline_templates/
In the template folder, /homeassistant/streamline_templates/debug.yaml
default:
  - light_icon: mdi:ceiling-light
card:
  type: custom:bubble-card
  icon: "[[light_icon]]"
  entity: "[[light_entity]]"
When loading the card with
type: custom:streamline-card
template: debug
I get:
The template "debug" doesn't exist in streamline_templates
template: debug
HomeAssisten Supervised installed on Homeassistent OS
Streamline card is avalible in dashboard resources
Already tried different path like
streamline_templates: !include_dir_named /streamline_templates/
streamline_templates: !include_dir_named ./streamline_templates/
streamline_templates: !include_dir_named …/streamline_templates/
In developer → template
I get
'streamline_templates' is undefined
When entering:
{{ streamline_templates.debug }}
I also have problems getting this to work. Maybe you can try
streamline_templates: !include_dir_merge_named streamline_templates/
I tried lots of things already, but non is working, yet.
The documentation is a bit unclear for me. It’s not clear where to put which directory and which file exactly.
The error I’m getting while checking the configuration is:
Integration error: streamline_templates - Integration ‘streamline_templates’ not found.
Not using this card, but perhaps that “include” line must be placed inside a particular key, like for each dashboard.
According to the documentation it should be in the main dashboard configuration file (which one is that exactly ?), but then I only get errors about an unknown tag,
After this I decided to follow one of the examples and not use yaml, but the UI.
Put the example code at the top of my dashboard file and it works, just like the decluttering card.
Now to find out how to use the yaml example.
Got it working after some tinkering.
At the top of the dashboard file put:
streamline_templates: ‘!include_dir_named …/streamline_templates/’
Don’t forget the two ’ '. (Although for me it works also if I leave the whole line out).
Under
www\community\streamline-card\
I created a file
streamline_templates.yaml
Then put the text for the template left-aligned in the file.
This works for me. I can use the template in my dashboard, but only in yaml mode, not in the UI.
I used this as an example:
light_template:
  default:
    - icon: mdi:lightbulb
      name: vul hier de naam lightbulb in
      type: button
      entity: null
  card:
    card_type: button
    button_type: "[[type]]"
    entity: "[[entity]]"
    icon: "[[icon]]"
    tap_action:
      action: toggle
    hold_action:
      action: more-info
and this is my example dashboard:
streamline_templates: '!include_dir_named ../streamline_templates/'
  - title: Home
    type: sections
    max_columns: 1
    sections:
      - type: grid
        cards:
          - type: custom:streamline-card
            template: light_template
            variables:
              - entity: light.dimmer_plafondlampen_light_2
              - type: slider
            grid_options:
              columns: full
@treinenwimke
Thanks for sharing.
I had also issues and with your example I made it work wiht a new created dashboard using the UI.
No matter what I do, I cannot get the template config available in the UI when using the sreamline_templates.yaml method or by including the individual template yaml files in /streamline_templates/.
Great! After a few hours of banging my head trying to get help from ChatGPT, your comment made everything clear.
Thanks for sharing your findings!
Hi, you explained the example very well, but unfortunately I still can’t get it to work:
I keep getting the error message ‘The template “deye_template” doesn’t exist in streamline_templates’.
Please take a look at the code below!
dashboard:
streamline_templates: ‘!include_dir_named ../streamline_templates/’
  - title: Home
    type: sections
    max_columns: 1
    sections:
      - type: grid
        cards:
            template: deye_template
            variables:
              - entity: time.deye_inverter_program_1_time
              - name: Startzeit
              - icon: mdi:clock-edit-outline
        grid_options:
          columns: full
deye_template:
  default:
    - icon: mdi:cog-box
  card:
    type: custom:entity
    icon: "[[icon]]"
    card_mod:
      style: |
        ha-card {
          height: 80px !important;
          color: #000000;
          background: #99FFCC;
        .name {
          font-size: 16px !important;
        .value {
          font-size: 20px !important;
        :host {
          {% if states('select.deye_inverter_program_1_charging') == 'Grid' %}
            --card-mod-icon-color: #FF0000;
          {% elif states('select.deye_inverter_program_1_charging') == 'Generator' %}
          {% else %}
            --card-mod-icon-color: #0000B8
          {% endif %}
I ask for your help - thank you very much!
You need a minus before ‘name:’ just like you did with ‘- icon:’
All entries below ‘default:’ need a minus sign.
Try this and let me know if it works.
