Stremio Integration (for apple tv)
So, I am a regular stremio user and usually have to copy the stream-url into the vlc app of my appleTV to get everything running well. Let’s say I grew tired of that. That’s why I created this integration, which at heart, is a stremio browser + appletv vlc launcher / link copier.
hacs-stremio4
Feedback is welcome. Apple TV needs to be turned on and VLC needs to be installed for it to work. In stremio-device options select Handover method: VLC, enable apple tv handover + enter the entity id of your appletv.
More Info & Screenshots @ https://github.com/tamaygz/hacs-stremio
Hi, just want to ask…if i am not using any apple devices, will this integration still usable for android tv?
@hapis.sarkawi
Well, if you explain me how you want to use it, I may be able to give a more useful answer. You will basically get the ability to query your library and the stremio catalog both via service/action or through UI dasboard cards. You can select streams and copy them to your clipboard.
The appletv part, I personally needed, because I wanted to launch the VLC app on AppleTV with the correct stream link, so I save manual copy paste navigation labour.
If you use a android/googletv for a similar use case, just describe your setup to me and what youd like to do (after testing so you can check whats missing), and I may be able to add it quickly.
Update: Release Release v0.5.37 · tamaygz/hacs-stremio · GitHub
New:
Dashboard cards to browse stremio catalogue indepently from your library. See popular/new movies/shows, search the catalogue with your input, add items to your library all through dashboard cards.
