loolpaso
(Stanislav)
1
Can you please tell me how to collapse the content of the Input text, e.g.:
Line1, Line2, Line3, ..., LineN
to JSON array of strings, e.g.:
"{"Array_name":["String1","String2","String3",...,"StringN"]}"
to send through MQTT with automation.
And vice versa - how to pass JSON array of strings, e.g.
to Input text, e.g.
Thank you.
Use templates:
![Open your Home Assistant instance and show your template developer tools.](https://community-assets.home-assistant.io/original/3X/e/5/e5b834b2d76018fcf455c01593add4289d16aa7a.svg)
Json to string:
{% set a = {"Array_name":["String1","String2","String3","StringN"]} %}
{{ a.Array_name | join(', ') }}
Drop the first line and replace a
with value_json
in your MQTT sensor’s value_template
String to json:
{% set a = 'Line1, Line2, Line3, ..., LineN' %}
{{ { "Array_name": a.split(', ') } | to_json }}
with the state of your input text and put the template in payload_template
when calling mqtt.publish
