I’m using the scrape sensor to bring in my current solar output and today’s peak from PVoutput.org.
When the Watts goes over 999, the number on the webpage gets a comma (eg 1,000 and over gets a comma). This is making HA interpret it as a string and not a number, and this is played out in my graphs which go to zero as soon as the value goes over 999.
Can I use a value template to strip out the comma? I’ve been doing some digging but haven’t found a way to do it.
ok, so I couldn’t wait so had a further dig into the jinja doco and found replace. (I didn’t realise jinja was a form of Python so figured python doco could help too).
Here’s the data_template I’ve used and it seems to work…
I know it’s been a long time since you posted this, but its still helping people out in 2023.
The error message that I got (and eventually led me to your issue) was from
multiscrape in homeassistant. I got these errors:
numerical_value = float(value) # type:ignore[arg-type]
ValueError: could not convert string to float: ‘1,053.90’
It took me a while to figure out that it was the comma. Thanks so much for finding, and fixing your issue!
I hope anyone else getting those errors in Home Assistant will be able to find this and get help.
I really wish the developers who maintain the Convert String to Float would make their error message a bit more helpful. Instead of saying “could not convert”, they could have said "Could not convert because unexpected character ‘,’ found in string.
