Strong fan mode not working after upgrading to new thermostat card card
The fan mode “Strong” which was available on the old card doesn’t work on the new one. Please check attached image.
All other modes work as expected and I can use the strong fan mode if I call the service through an automation. So I suppose i’ts just a problem in the front end.
Using Sensibo Sky Integration.
  • Edit: I CANNOT use the strong fan mode if I call the service through an automation.
    I hade a remote_send command in the automation and that’s why it was working. I forgot I had copied the IR code to be sent through Broadlink RM3 in order to emulate the strong fan mode button press.
Thanks,
