I’m building a toy for my sons 2nd birthday. it will be an wall hanged activation board with electronic features.
I have three buttons they will do different things.
if i press button one of the 3 buttons i whish to disable the three buttons so that i don’t trigger the same script or another simultaneous.
1 i have tried to do this with a binary_template_switch but i cant make it work
2 i have solved the problem with a gpio switch but i dont whis to waste a GPIO
3 when i added the solution gpio solution i cant get the repeat to work anymore.
does anyone have a better way to the blocking of simultaneous scripts?
what is wrong with the GPIO version why did the repeat stop working?
switch:
optimistic: true
- platform: gpio
` on_press:
then:
if:
condition:
lambda: 'return id(modebutton).state = "0";'
then:
#With a regular switch (works)
binary_sensor:
- platform: gpio
pin:
number: D1
mode: INPUT_PULLUP
inverted: True
on_press:
then:
- if:
condition:
switch.is_off: modebutton
then:
- repeat:
count: 5
then: #(line 79)
- switch.turn_on: modebutton
- switch.turn_off: ledyellow
- switch.turn_off: ledgreen
- delay: 7s
- switch.turn_off: ledred
- switch.turn_on: ledyellow
- delay: 2s
- switch.turn_on: ledgreen
- delay: 7s
- delay: 4s
- switch.turn_off: modebutton
ERROR Error while reading config: Invalid YAML syntax:
mapping values are not allowed here
in "/config/esphome/esp-008-activationboard-v2.yaml", line 79, column 23:
then:
Thanx in advance for your time!
