Daniel87
(Mr Daniel Midgley)
February 2, 2019, 5:25pm
1
I have a RaspPi configured with Raspbien and have installed letsencrypt.
I can access HA on IP:8123 but not on https://domain.duckdns.org
I have forwarded port 443 to 8123 TCP/UDP on my router settings.
In Chrome i get:
This site can’t be reached
domain.duckdns.org unexpectedly closed the connection.
ERR_CONNECTION_CLOSED
home-assistant.log is showing various versions of this
2019-02-02 16:33:51 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 275, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp\_http_parser.pyx", line 523, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
Any thoughts on troubleshooting please?
tom_l
February 2, 2019, 5:37pm
2
Show us your http: config from configuration.yaml (appropriately redacted).
Are you trying from within or from without your local network (use your mobile with wifi off)?
Daniel87
(Mr Daniel Midgley)
February 2, 2019, 7:05pm
3
I’ve Googled this and it suggests something may be wrong with my configuration file. This is what it looks like
http:
base_url: https://domain.duckdns.org
api_password: blabla
ssl_certificate: /etc/letsencrypt/live/domain.duckdns.org/fullchain.pem
ssl_key: /etc/letsencrypt/live/domain.duckdns.org/privkey.pem
Daniel87
(Mr Daniel Midgley)
February 2, 2019, 7:24pm
4
Ah - ha
Apologies, couldn’t post the full info to start due to not being able to create a post with more than 2 links… and then my account was suspended for some reason for an hour or so.
Anyway, thanks for your response Tom. I have managed to resolve the issue!
What i needed to do was
sudo chmod 755 /etc/letsencrypt/live/
sudo chmod 755 /etc/letsencrypt/archive/
Solved the issue for me! Hope it helps someone else too.
