Struggling to add FGS-222 - SOLVED
I have 10 z-wave devices linked to my z-wave USB stick on a RPi 3 running Hass.io. I recently bought a Fibaro FGS-222 on eBay and am really struggling to add it so wondering if anyone has any pearls of wisdom that I could try.
I have successfully wired in and added two FGS-223 modules over the last couple of days so am happy that my wiring is correct and also that the process I am using to add them is correct.
So far I have tried:
Holding the B button for 3 seconds whilst power is applied to the module (both with just the live wire and also with all wires connected) to try and factory reset.
I have tried adding as both secure and non secure through the Hass.io Z-wave menu. I have tried flicking the switch three times from off, three times from on and also pressing the B button once and three times quickly to add but on every occasion… nothing.
Pressing the B Button does switch the light so I am assuming that the device is not dead.
From previous Z wave devices that are second hand, I know they can sometimes be a bit tricky so I am curious if there are any other steps I could try.
The only issue I can see from my z wave log is that a fibaro motion sensor in the same room seems to be very ‘busy’ at the time:
2018-10-21 09:25:17.793 Info, Node029, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2018-10-21 09:25:17.794 Detail, Node029, Refreshed Value: old value=0, new value=0, type=byte
2018-10-21 09:25:17.794 Detail, Node029, Changes to this value are not verified
2018-10-21 09:25:17.795 Detail, Node029, Changes to this value are not verified
2018-10-21 09:25:17.795 Detail, Node029, Refreshed Value: old value=0, new value=0, type=byte
2018-10-21 09:25:17.795 Detail, Node029, Notification: ValueChanged
2018-10-21 09:25:17.823 Detail, Node029, Notification: ValueChanged
2018-10-21 09:25:17.878 Detail, Node029, Notification: ValueChanged
2018-10-21 09:25:17.921 Detail, Node029, Notification: ValueChanged
So not sure if this is flooding the network and delaying the add signal?
Is it possible to turn off the motion sensor?
I ended up with a combination of painting the sensor at the wall and then clicking as fast as I could to remove and then pair (from a google link I found it would seem that the 222 pairing process requires faster clicking than the 223 pairing process!)
All solved.
Just created an account to second what John wrote above:
To pair FGS-222, you’ll have to press the B button three times in crazy fast succession. And I mean crazy fast, like three times within 0.5 seconds. Any slower, and the relays will just switch rather than an inclusion or exclusion process starting.
My main issue is control, I have a Curtain I can’t get to close or open more than few CM at a time, they go all the way if I pull the Curtain a bit and is able to go back when activated and calibrated, but thats the end of that, any tips?
