I’ve installed the app to my son’s phone - however I’m having trouble getting it to report it’s location.
The device name is Oliver. I’ve add an entry to known_devices
oliver:
hide_if_away: false
track: true
but no matter what I do I seem to get the same error every time I push location from the phone:
2018-02-18 19:41:33 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall device_tracker.see: gps_accuracy=65, battery=98, gps=[xxxx, yyyy], hostname=Oliver’s iPhone, dev_id=Oliver , battery_status=Unplugged>
File “/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/core.py”, line 1010, in event_to_service_call
yield from service_handler.func(service_call)
File “/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/init.py”, line 209, in async_see_service
yield from tracker.async_see(**args)
File “/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/init.py”, line 272, in async_see
dev_id = cv.slug(str(dev_id).lower())
File “/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/config_validation.py”, line 299, in slug
raise vol.Invalid(‘invalid slug {} (try {})’.format(value, slg))
voluptuous.error.Invalid: invalid slug oliver (try oliver)
2018-02-18 19:41:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: source=helpers/config_validation.py, level=ERROR, exception=Traceback (most recent call last):
What am I doing wrong?
