Diagnostics
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2025.1.1",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.13.1",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/London",
"os_name": "Linux",
"os_version": "6.6.66-haos",
"supervisor": "2024.12.3",
"host_os": "Home Assistant OS 14.1",
"docker_version": "27.2.0",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"meross_lan": {
"documentation": "https://github.com/krahabb/meross_lan",
"version": "5.4.1",
"requirements": []
"ble_monitor": {
"documentation": "https://github.com/custom-components/ble_monitor",
"version": "13.0.0",
"requirements": [
"pycryptodomex>=3.21.0",
"janus>=2.0.0",
"aioblescan>=0.2.14",
"btsocket>=0.3.0",
"pyric>=0.1.6.3"
"hacs": {
"documentation": "https://hacs.xyz/docs/use/",
"version": "2.0.2",
"requirements": [
"aiogithubapi>=22.10.1"
"govee_ble_hci": {
"documentation": "https://github.com/Home-Is-Where-You-Hang-Your-Hack/sensor.goveetemp_bt_hci",
"version": "0.10.3",
"requirements": [
"bleson==0.1.8"
"localtuya": {
"documentation": "https://github.com/rospogrigio/localtuya/",
"version": "5.2.1",
"requirements": []
"octopus_energy": {
"documentation": "https://bottlecapdave.github.io/HomeAssistant-OctopusEnergy",
"version": "13.5.0",
"requirements": [
"pydantic"
"integration_manifest": {
"domain": "esphome",
"name": "ESPHome",
"after_dependencies": [
"zeroconf",
"tag"
"codeowners": [
"OttoWinter",
"jesserockz",
"kbx81",
"bdraco"
"config_flow": true,
"dependencies": [
"assist_pipeline",
"bluetooth",
"intent",
"ffmpeg",
"http"
"dhcp": [
"registered_devices": true
"documentation": "https://www.home-assistant.io/integrations/esphome",
"integration_type": "device",
"iot_class": "local_push",
"loggers": [
"aioesphomeapi",
"noiseprotocol",
"bleak_esphome"
"mqtt": [
"esphome/discover/#"
"requirements": [
"aioesphomeapi==28.0.0",
"esphome-dashboard-api==1.2.3",
"bleak-esphome==2.0.0"
"zeroconf": [
"_esphomelib._tcp.local."
"is_built_in": true,
"overwrites_built_in": false
"setup_times": {
"null": {
"setup": 0.07407927699387074
"01JGEBVYAXFX09BVWV15WTYABX": {
"wait_import_platforms": -1.0212713939836249,
"config_entry_setup": 1.107525696977973
"01JGC2GWQ7GEZRPA5QA3HPW0EE": {
"wait_import_platforms": -1.0253774009179324,
"config_entry_setup": 1.109004080062732
"data": {
"config": {
"created_at": "2024-12-31T12:43:19.773931+00:00",
"data": {
"device_name": "esphome-web-c9388c",
"host": "192.168.1.13",
"noise_psk": "",
"password": "",
"port": 6053
"discovery_keys": {
"dhcp": [
"__type": "<class 'homeassistant.helpers.discovery_flow.DiscoveryKey'>",
"repr": "DiscoveryKey(domain='dhcp', key='142b2fc9388c', version=1)"
"zeroconf": [
"repr": "DiscoveryKey(domain='zeroconf', key=('_esphomelib._tcp.local.', 'esphome-web-c9388c._esphomelib._tcp.local.'), version=1)"
"disabled_by": null,
"entry_id": "01JGEBVYAXFX09BVWV15WTYABX",
"minor_version": 1,
"modified_at": "2025-01-06T07:42:36.665574+00:00",
"options": {
"allow_service_calls": true
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "user",
"title": "ESPHome Web c9388c",
"unique_id": "14:2b:2f:c9:38:8c",
"version": 1
"storage_data": {
"device_info": {
"uses_password": false,
"name": "esphome-web-c9388c",
"friendly_name": "ESPHome Web c9388c",
"mac_address": "**REDACTED**",
"compilation_time": "Nov 25 2024, 08:39:04",
"model": "esp32dev",
"manufacturer": "Espressif",
"has_deep_sleep": false,
"esphome_version": "2024.11.1",
"project_name": "esphome.web",
"project_version": "24.11.1",
"webserver_port": 80,
"legacy_voice_assistant_version": 0,
"voice_assistant_feature_flags": 0,
"legacy_bluetooth_proxy_version": 0,
"bluetooth_proxy_feature_flags": 0,
"suggested_area": ""
"services": [],
"api_version": {
"major": 1,
"minor": 10
"update": []
"dashboard": "5c53de3b_esphome"
