I have been dabbling in HA (running in an ESXi VM) the last couple months when SmartThings announced my hub was being deprecated (ST/ADT hub).
I’ve been slowly moving over my devices but have hit a snag where I didn’t expect one. I have a z-wave diming switch that I had mirrored to a Hue white bulb. This allowed me to use the physical z-wave switch to turn on/off the overhead light and the floor lamp at the same brightness. I’ve read several posts about trying to replicate this and I’ve tried the ideas but nothing has worked. Below is the last example I tried, I’d love some help in getting this working.
- action:
- service: light.turn_on
entity_id: light.living_room_lamp
data_template:
brightness: '{{ states.light.in_wall_dimmer_switch_5.attributes.brightness }}'
alias: Living Room Lamp On
- entity_id: light.in_wall_dimmer_switch_5
platform: state
to: 'on'
value_template: '{{ states.light.in_wall_dimmer_switch_5.attributes.brightness }}'
- action:
- entity_id: light.living_room_lamp
service: light.turn_off
alias: Living Room Lamp Off
platform: state
to: 'off'
- alias: Living Room Lamp Mirror
- platform: state # this will trigger on all state and attribute changes
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
- service: light.turn_off
- conditions:
- condition: state
state: 'on'
sequence:
brightness: "{{ state_attr('light.in_wall_dimmer_switch_5', 'brightness') }}"
One issue with your original “light on” triggers was that the template did not resolve to true or false as required for template triggers. This:
platform: state
to: 'on'
Would never trigger on brightness change. This would:
platform: state
to: 'on'
- platform: state
attribute: brightness
Thank you Tom, appreciate you taking a look at this. I’m getting these errors, feeling beat up by this:
2021-03-29 18:14:20 ERROR (SyncWorker_5) [homeassistant.util.yaml.loader] while parsing a block collection
in “/config/configuration.yaml”, line 11, column 3
expected , but found ‘?’
in “/config/configuration.yaml”, line 14, column 3
2021-03-29 18:14:20 ERROR (MainThread) [homeassistant.components.hassio] Error loading /config/configuration.yaml: while parsing a block collection
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Text to speech
tts:
- platform: google_translate
# Sync Living Room Lights
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
- conditions:
- condition: state
state: 'on'
sequence:
This line tells Home Assistant that your automations are located in a separate file:
However, you pasted tom_I’s example into your configuration.yaml file.
Remove it from there and add it to the automations.yaml file. In addition, you left out the leading hyphen on the first line (don’t forget to add it, as shown in tom_I’s example).
Once that’s done, execute Configuration > Server Controls > Check Configuration. If it passes, execute Reload Automations.
