I am in the process of (hopefully) pulling away from Smartthings using the official HASS.IO distro for Raspberry Pi 4 (4Gb version). My first approach was to integrate all wifi/web-based IOT items into HASS and that was successful. I run a number of z-wave and zigbee devices as well so my next step was to move over some basic z-wave devices (simple and common toggle-switches) to see how that went. Well, it hasn’t. I am using a Zooz USB dongle and OpenZWave 1.6. I can successfully add nodes of various manufactures, but they never get fully provisioned. All get through the initial communication put fail on the final probe. Have tried a mix of GE, Lutron and Levitron devices, all to the same end. Any thoghts or should I stop banging my head against the wall and use some other z-wave add-in (ZWave JS?)? I have included an example of the final attempts and the result:
[20210308 7:58:59.377 EST] [ozw.library] [debug]: Detail - Node: 10 ZW_SEND_DATA delivered to Z-Wave stack
[20210308 7:59:03.516 EST] [ozw.library] [debug]: Detail - Node: 10 Received: 0x01, 0x18, 0x00, 0x13, 0x0d, 0x01, 0x01, 0x9f, 0x00, 0x7f, 0x7f, 0x7f, 0x7f, 0x7f, 0x01, 0x01, 0x07, 0x00, 0x00, 0x00, 0x00, 0x02, 0x04, 0x00, 0x00, 0x18
[20210308 7:59:03.516 EST] [ozw.library] [debug]: Detail - Node: 10 ZW_SEND_DATA Request with callback ID 0x0d received (expected 0x0d)
[20210308 7:59:03.516 EST] [ozw.library] [debug]: Detail - Node: 10 Extended TxStatus: Time: 4150, Hops: 0, Rssi: — — — — —, AckChannel: 1, TxChannel: 1, RouteScheme: Explorer Route, Route: 0 0 0 0, RouteSpeed: 40K, RouteTries: 4, FailedLinkFrom: 0, FailedLinkTo: 0
[20210308 7:59:03.517 EST] [ozw.library] [info]: Info - Node: 10 WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
[20210308 7:59:03.517 EST] [ozw.library] [warning]: Warning - Node: 10 WARNING: Device is not a sleeping node.
[20210308 7:59:03.517 EST] [ozw.library] [critical]: Error - Node: 10 ERROR: node presumed dead
[20210308 7:59:03.517 EST] [ozw.library] [warning]: Warning - Node: 0 CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
[20210308 7:59:03.517 EST] [ozw.library] [info]: Info - Node: 0 Saving Cache
[20210308 7:59:03.518 EST] [ozw.library] [info]: Info - Node: 1 Cache Save for Node 1 as its QueryStage_CacheLoad
[20210308 7:59:03.518 EST] [ozw.library] [info]: Info - Node: 10 Skipping Cache Save for Node 10 as its not past QueryStage_CacheLoad
[20210308 7:59:03.521 EST] [ozw.library] [info]: Info - Node: 10 QueryStageRetry stage Probe requested stage Probe max 3 retries 2 pending 1
[20210308 7:59:03.521 EST] [ozw.library] [debug]: Detail - Node: 10 Expected callbackId was received
[20210308 7:59:03.521 EST] [ozw.library] [debug]: Detail - Node: 10 Expected reply was received
[20210308 7:59:03.522 EST] [ozw.library] [debug]: Detail - Node: 10 Message transaction complete
[20210308 7:59:03.522 EST] [ozw.library] [debug]: Detail - Node: 10 Removing current message
[20210308 7:59:03.522 EST] [ozw.library] [debug]: Detail - Node: 10 Notification: Notification - NoOperation
[20210308 7:59:03.522 EST] [ozw.library] [debug]: Detail - Node: 10 Notification: Notification - Node Dead
[20210308 7:59:03.522 EST] [ozw.notifications] [debug]: Notification pvt_ozwNotification NotificationTypes::Notification_Code_NoOperation Thread: 0x7f89b27e38
[20210308 7:59:03.523 EST] [ozw.library] [debug]: Detail - Node: 10 Query Stage Complete (Probe)
[20210308 7:59:03.523 EST] [ozw.library] [debug]: Detail - Node: 10 AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=0
