Hey Folks,
I have reached the point of needing to get Nginx working in order to add on yet more sensors. However, due to the RasperryPi the system runs on also being needed to run pi-hole, I opted for the Docker version of HA. This has served me well but I cannot get it to play nicely with the nginx add-on. I have poured over the forums and feel like I am almost there, but I am clearly missing something. Is anyone able to offer any pointers?
Here is my current setup and status:
Currently working: internal URL works fine
Currently not working: external URL does not load - it just sits loading forever
configuration.yaml:
homeassistant:
external_url: "https://MYDOMAIN.duckdns.org"
internal_url: "http://192.168.86.194:8123"
http:
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
use_x_forwarded_for: true
trusted_proxies:
- 192.168.86.0/24 # Local Lan
- 172.30.33.0/24 # Docker network
docker inspect -f ‘{{range.NetworkSettings.Networks}}{{.IPAddress}}{{end}}’ NGINX-ADDON
172.30.33.2
Nginx addon config
certfile: fullchain.pem
cloudflare: false
customize:
active: false
default: nginx_proxy_default*.conf
servers: nginx_proxy/*.conf
domain: MYDOMAIN.duckdns.org
hsts: max-age=31536000; includeSubDomains
keyfile: privkey.pem
Nginx log (from HA addon)
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[18:39:34] INFO: Running nginx...
