Struggling trying to get Frigate running
I have HA running in a Proxmox VM and I’m trying to setup Frigate for my one Amcrest IP8M-2496EW camera. I’ve installed MQTT, HACS and Frigate. Created frigate.yml file with the yaml code and made the changes to the file. I’m getting these errors in the log after starting:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[2023-02-11 14:28:53] frigate.app INFO : Starting Frigate (0.11.1-2eada21)
*** Your config file is not valid! ***
*** Please check the docs at ***
*** Configuration File | Frigate ***
*** Config Validation Errors ***
3 validation errors for FrigateConfig
cameras → driveway_cam → fps
extra fields not permitted (type=value_error.extra)
cameras → driveway_cam → height
cameras → driveway_cam → width
File “/opt/frigate/frigate/app.py”, line 332, in start
self.init_config()
File “/opt/frigate/frigate/app.py”, line 82, in init_config
user_config = FrigateConfig.parse_file(config_file)
File “/opt/frigate/frigate/config.py”, line 942, in parse_file
return cls.parse_obj(config)
File “pydantic/main.py”, line 521, in pydantic.main.BaseModel.parse_obj
File “pydantic/main.py”, line 341, in pydantic.main.BaseModel.init
pydantic.error_wrappers.ValidationError: 3 validation errors for FrigateConfig
*** End Config Validation Errors ***
[cmd] python3 exited 1
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
I can access the camera IP address on my home network so I know it’s working. I don’t understand “extra fields not permitted” in the HA log.
Here’s the frigate.yml file:
mqtt:
  host: xxx.xxx.x.xx
  user: admin
  password: xxxxxxxxxx
cameras:
  driveway_cam:
    ffmpeg:
      inputs:
        - path: rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0&authbasic=64
          roles:
            - detect
    width: 1280
    height: 720
    fps: 10
detectors:
  cpu1:
    type: cpu
  cpu2:
    type: cpu
Any help would be greatly appreciated.
width, height, and fps go under detect in the camera configuration
cameras:
  driveway_cam:
    ffmpeg:
    detect:
      width: 1280
      height: 720
      fps: 10
Cool, I think I got it. I should say, you got it.
Many thanks.
