Struggling with custom intent
I’m trying to create a custom intent that changes the value of an input_number helper.
In my sentences/en/jarvis.yaml file I have
language: "en"
intents:
  SetCarBatteryLevel:
      - sentences:
          - "set the car battery to seventy percent"
and in my intent_script I have
intent_script:
  SetCarBatteryLevel:
      - action: input_number.set_value
          entity_id: input_number.car_battery_charge_level
          value: 70
If I ask Assist to “set the car battery charge level to 70%” it does exactly that.
How do I make the value part a variable that is captured by the custom sentence and passed to the intent script?
I’ve tried using trigger slots, as in
  SetCarBatteryLevel:
      - sentences:
          - "set the car battery charge level to {value} percent"
and
 SetCarBatteryLevel:
          value: "{{trigger.slots.value}}"
but that didn’t work and the intent was not processed locally.
To set my heating I have:
CustomSetTemperature:
    - service: climate.set_temperature
        temperature: "{{ temp }}"
        entity_id: climate.hallway
Edit: Sorry, should have included the sentence:
language: "en"
intents:
      - sentences:
          - "(set|change) [the] (temperature | heating | thermostat) to {temp} [degrees]"
lists:
  temp:
    range:
      to: 35
Yeah, I also tried
SetCarBatteryLevel:
        value: "{{ value }}"
that didn’t work. I know setting a fixed number works so it’s just getting the variable right.
If you are using yaml, you need to set the type of the variable.
For example
lists:
  value :
    range:
      to: 100
Also check which way numbers are recognized, as words or as digits.
I tried that too
  SetCarBatteryLevel:
      - sentences:
          - "(set|change) [the] car (battery|battery level) to {value} [percent]"
        requires_context:
          domain: "input_number"
        lists:
          value:
            range:
              to: 100
I think this might be the root of the issue. If I simply put
        value:  70
in the intent script, it clearly recognises 70 as a number. However, if I try to use a wildcard such as {value} then instead of the number 70, put {{value}} in the intent script, am I hitting a formatting issue where the {{value}} variable is rendered as a something other than a number. In which case, something like {{value|int}} should work. But if that’s the case, why does {temp} and {{temp}} work in @jackjourneyman example work?
I did wonder if it’s because there is already a built-in intent to change the temperature of a climate entity, but there is no built-in intent that can change the value of an input_number helper.
If other commands with numeric values work, there is nothing wrong with the format.
Try removing
        requires_context:
Your phrase is unique enough that it won’t conflict with the built-in intents.
If that doesn’t help either, do the automation in the GUI, there’s less chance of error there, and all new variables are automatically assigned the wildcard type
Okay, this is interesting.
In my custom_sentences/en/jarvis.yaml file I have
language: "en"
intents:
  SetCarBatteryLevel:
      - sentences:
          - "(set|change) [the] car (battery charge|battery charge level) to {value} [percent]"
        lists:
          value:
            range:
              to: 100
Now when I use the Assist sentence parser in Developer Tools to test the sentence by typing “set the car battery charge level to 90 percent” I get the following result:
intent:
slots:
  value: '90'
details:
  value:
    value: 90
    text: '90'
targets: {}
match: true
sentence_template: >-
  [percent]
unmatched_slots: {}
source: custom
file: en/jarvis.yaml
So the intent is being correctly recognised. It’s obviously what I have in the intent_script that is not being correctly processed.
Here’s what’s in the intent_script.
First of all , my intent_script is in a file called intent_script.yaml which is correctly located in the homeassistant/ directory. I have correctly pointed my config towards it by having the line
intent_script: !include intent_script.yaml
Inside the intent_script.yaml file I have
  SetCarBatteryLevel:
and it still doesn’t work!
Okay, I’m closing this one off here. I could not get the custom sentence and intent in a script to work so I went for an automation instead.
It took a bit of digging to get the right variable to use and to strip off the % sign after the number, but this automation works.
alias: Set Car Battery Level via Assist
triggers:
  - command:
        (set|change) [the] car (battery charge|battery charge level) to {number}
        [percent]
    trigger: conversation
conditions: []
actions:
  - variables:
      level: "{{ trigger.slots['number'] | regex_replace('%', '') | int }}"
  - target:
      value: "{{ level }}"
mode: single
This saved me a lot of heartache - thank you! As a reference for others - this helped too when trying to change my AC temp that is controlled with an input_number (and automations taking care of the actual AC changes). There seems to be no way to override the built-in intents for AC changes
